Results 1 to 7 of 7
09-16-2019, 03:27 PM #1
Rubber grommets for Raptor engine cover
2 out of the 3 rubber grommets that are on the engine cover in order to hold it to the engine plastic mounts are torn. I called a ford dealer and my local Indmar dealer and having difficulty finding them. Anyone know where I can find them?
Thanks2015 Moomba Mondo Surf Edition
WM 910 Rear sacs and 650 and 550 IBS
WS 600 WATT Amp- 4 Tower Speakers
KICKER 800 WATT Amp-Sub
Ford Raptor 400 6.2 L
Pro sport 12 Dual Batt Charger
Acme Prop 14.5 x 14.25
Winston Salem
North Carolina
09-16-2019, 04:43 PM #2
Not a Ford part, it’s an Indmar part.
I would contact Indmar directly for guidance.
Certainly if you have a part number from Indmar, you could at least order it from your Indmar dealer.
Sent from my iPhone using Tapatalk2021 Supra SA 400
2018 Supra SA 400 (SOLD)
Michigan
04-17-2021, 05:59 PM #3
04-18-2021, 07:06 PM #4Junior Member
- Sep 2017
- 1
I had the same issue last year. The part number is 551396. My dealer got them from Indmar. I also found them at https://inboardonline.com/indmar/?page=8 . Description on website - MOUNTING STUD FOR BEAUTY COVER,551396
05-31-2021, 08:40 PM #5
What is the part number for the grommet? The part number given is for the stud.
06-01-2021, 10:45 AM #6
The part number for the rapter 6.2 L grommet is 986389 and can be found on inboardline.com It will say it is for GM, but according to Larry Engelbart with Indmar it is the same part for both.
06-02-2021, 11:41 AM #7
