Results 1 to 6 of 6
    Jul 2015
    Alberta
    Default Antifreeze help!
    Boat will be outside freezing for the first time ever (2015 raptor engine). I have done the regular winterization stuff but when I tested the coolant it’s only good to -10. So I need to top up it up or change. Dealer if 4 hours away. Just looking for some tips. Drain some out top up and run engine pump it through? Any tips would be appreciated. Where to drain from etc. Manual indicates they can be a challenge to get air out if full drain done?
    Thanks for your help.
    2015 Moomba Mondo surf
    Auto flow surf 2.0
    Nautic logic gps
    Samson reverse arch
    1100 fat sac.
    May 2018
    You should get your mix of Propylene glycol and water close to 50/50. Be sure not to mix in ethylene glycol by mistake.
    This will protect to -29f
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
    Jul 2015
    Alberta
    Thanks for the response. I have ordered a new tester as apparently they are different for the propylene vs ethylene. Hopefully I will be good once I use the proper gauge.
    Auto flow surf 2.0
    Nautic logic gps
    Samson reverse arch
    1100 fat sac.
    Better late than never!
    https://www.indmardealersupport.com/news-letter.php
    That link gives detailed instructions and pictures on how to change the coolant on a Raptor. Looks easy enough.
    May 2018
    Quote Originally Posted by JHCMondo View Post
    Interesting that the procedure is pull the main coolant hose and dump it into the hull.
    Lol
    2021 Supra SA 400
    Michigan
    Yeah I know. I was hoping to suction it out.
    I'll just drain it in the hull and use a bucket at the center drain hole.
