Results 21 to 30 of 38
Thread: water in oil
    Water in the crankcase from cracked exhaust manifolds is certainly not the most direct path, but I would never say never. On the same side of the coin, if an engine ran hot enough, its toast. Thats the worst thing you can do to an engine. Cylinders get out of round, pistons scuff, heads and block warps, etc.
    May 2018
    If you cracked an exhaust manifold, I am sure you could also crack a water jacket and or cracked a cylinder.
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
    Commerce Lake, MI
    Yeah...that I can agree with! It’s nots the cracked manifolds that let the water in.
    Hence why I said have the motor compression checked otherwise new manifold aren’t going to do jack shit to fix a cracked block!
    2017 Moomba Craz
  4. #24
    Dec 2018
    Phoenix AZ
    I’m guessing every time you shut the engine off water could flow into the exhaust and get into the crankcase through the exhaust valve. That’s the only thing that makes sense to me.
  5. #25
    Commerce Lake, MI
    Quote Originally Posted by Turbinesurgeon View Post
    The piston rings would have to be completely fucked for that to happen.
    2017 Moomba Craz
  6. #26
    Dec 2018
    Phoenix AZ
    Yeah your right. Must have overheated and cracked a head or something.
  7. #27
    This^^^^^....when shut off water can flow thru exhaust valve into cylinder head. The water will then seep past the ring gaps into the crank case.
    The question is where did the water in the bilge come from? What hose came off? I would not think a ballast hose would cause an overheat issue. Was the water warm in the bilge? Why did the automatic bilge pump not come on? When was the oil level last checked.
    99 Outback LS. Sold
  8. #28
    Aug 2017
    That would hydrolock the engine. Had it happen on a 92 Seaswirl several years ago.
    2019 Supra SL450
  9. #29
    Water will sit in the cylinders for a LONG time. Next start up, you would be hydro-locked.
  10. #30
    Salt Lake City, Utah
    Docdrs brings up a good point of why did the automatic bilge not turn on. Better make sure that gets checked out.
    Scott
    2021 Craz
    1997 Sea Ray 190
