Results 1 to 10 of 10
02-26-2007, 09:00 PM #1Senior Member
- Sep 2005
- Austin, Tejas
- 491
so uh....I just drilled a hole through the hull of my boat
oops ..... I was mounting the amp rack and it looked like it was safe to run a screw into the hull, obviously it wasn't. Now I have a 5/32" hole in the bottom of my boat, any idea what the best way to fix it would be? I'd like to do it myself, I know I can handle it. I just don't know what to use to fill the hole and you can get gelcoat repair kits from Academy. Any suggestions?
02-27-2007, 05:53 AM #2
You won't be able to just do the gelcoat thing....you hafta 'glass it too.
Just putting gel-coat would kinda be like spackling the hole, You prolly would want to reinforce it
B
02-27-2007, 10:00 AM #3Senior Member
- Aug 2002
- Bismarck, NorthDakota
- 579
OUCH!!!!
I would at least get a estimate from a fiberglass shop, you might be surprised.
again, OUCH!
good luck with the repair!Bruce Fuerstenberg
02-27-2007, 12:03 PM #4Senior Member
- Sep 2005
- Austin, Tejas
- 491
it's going to be an easy fix since it's such a small hole. I'm going to seal the hole from the bottom and use a large syringe to inject fiberglass resin into the hole. It won't take much at all. Once it's dry I'll hit the bottom with the gelcoat repair kit and see how that comes out. If it looks bad then I'll take it to the shop to get the gel coat touched up.
02-27-2007, 12:05 PM #5
That'll prolly work just fine.
B
02-27-2007, 12:38 PM #6
Well besides ventilating the hull...how did the amp rack turn out? And you know we need pictures of your progress.
15 Mondo Surf Edition
02 LSV - Traded In
02-27-2007, 03:13 PM #7Senior Member
- Sep 2005
- Austin, Tejas
- 491
Originally Posted by JesseC
02-27-2007, 09:16 PM #8Senior Member
- Feb 2006
- Fayetteville, GA
- 319
02-27-2007, 09:48 PM #9Senior Member
- Mar 2005
- t-town
- 718
Originally Posted by Wolf-
02-27-2007, 10:09 PM #10Senior Member
- Sep 2005
- Austin, Tejas
- 491
I thought about that too, but it was to far forward and would be out of the water once the boat was on plane
What size hole for ballast bilge? Dual Battery question also
By sethscott in forum General ChatReplies: 4Last Post: 03-03-2008, 07:12 PM -
Cleaning Hull?
By Waynes345 in forum Service & RepairReplies: 5Last Post: 09-05-2007, 04:53 PM -
Thru hull scoop
By pmann in forum General ChatReplies: 0Last Post: 06-02-2006, 08:55 PM -
Hull Damage
By Panhandler in forum General ChatReplies: 3Last Post: 04-21-2004, 07:06 PM -
Thru Hull Fitting
By pjtatro in forum General ChatReplies: 1Last Post: 04-07-2003, 11:00 PM
