    Default Wet sounds mounted to oz tower
    I知 seeing if anyone has mounted there wet sounds on to the holes for a rack on the top part of the OZ tower. If anyone knows what I知 talking about prob not best description.
    Oct 2010
    Lake Wylie NC Area
    Looking to mount a tower pod to a board rack location?
    Yes the top rack spot. There are holes but I never use them and don稚 need another rack.
    Oct 2010
    Lake Wylie NC Area
    Id not want them down that low, if I could avoid it. Next, getting wire into the pod. You would have to convert the pod to the rear located 4-way speakon connector. Again, if rather not want that. Lets say the hole lined up, I bet you would need to use a spacer or the TC3-SBASE mounts so the pod cleared the tower. Worst case, you have to fabricate an adapter that bolted to the tower holes, then the pod bolted to the adapter.
    So I知 guessing nobody has tried it?!?
