Results 11 to 15 of 15
Thread: Normal Engine Temp Raptor 400
07-16-2020, 02:39 PM #11
2021 Supra SA 400
2018 Moomba Max - Wakemakers upgrade ballast kit (Sold)
2005 Four Winns 170 Horizon (Sold)
07-16-2020, 02:55 PM #12
My heater is located under a carpeted cover right at the engine cover opening. Two screws to remove cover and the heater pump is right there.
The heater hose then runs down the port side of the engine, SC uses crimp clamps, you need special pliers to tighten them or replace them with worm gear clamps.
Mine had a slow drip and I would need to refill maybe half a reservoir every 10 hours. Tightened clamps and never dropped coolant again.
2018 Supra SA 400 (SOLD)
Michigan
05-22-2022, 03:57 PM #13Junior Member
- Oct 2021
- Dallas TX
- 10
At what temp does the heater start blowing warmer air? New to inboards, too.
05-22-2022, 04:09 PM #142015 Moomba Mojo Surf Edition
4,000lbs
Manual Flow
05-22-2022, 05:23 PM #15
Yep to what HMB said. Just think of it like your car or truck. Air won't get warm until the engine temp or coolant gets up there. Unless you have a Tesla of course.
