Results 11 to 15 of 15
    Mar 2020
    MN
    Not normal, if you have a heater, check that the hose clamps are tight.
    I do have the heater, I’ll check that out. I’m a complete newb with inboards as we just picked up the boat in June, where are the clamps located. It’s a raptor 400 if that matters
    2021 Supra SA 400
    2018 Moomba Max - Wakemakers upgrade ballast kit (Sold)
    2005 Four Winns 170 Horizon (Sold)
    May 2018
    Quote Originally Posted by Swervy View Post
    My heater is located under a carpeted cover right at the engine cover opening. Two screws to remove cover and the heater pump is right there.
    The heater hose then runs down the port side of the engine, SC uses crimp clamps, you need special pliers to tighten them or replace them with worm gear clamps.
    Mine had a slow drip and I would need to refill maybe half a reservoir every 10 hours. Tightened clamps and never dropped coolant again.
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
    Oct 2021
    Dallas TX
    At what temp does the heater start blowing warmer air? New to inboards, too.
    Jan 2021
    Columbus, Ohio
    Quote Originally Posted by MELVIN View Post
    Your heater circuit is part of the closed loop anti-freeze with your engine. The heat exchanger will never go higher than engine temp. My boat at normal cruise is 167 so I wouldn't expect air to be much higher than 120 with thermal loss from the fan blowing.
    2015 Moomba Mojo Surf Edition
    4,000lbs
    Manual Flow
    Mar 2021
    South Georgia
    Yep to what HMB said. Just think of it like your car or truck. Air won't get warm until the engine temp or coolant gets up there. Unless you have a Tesla of course.
    2021 Moomba Makai
