Results 1 to 9 of 9
Thread: What oil are you using?
07-23-2019, 10:37 PM #1Senior Member
- Mar 2017
- Middle TN
- 232
Looking to do the 20hr oil/fluid change.
What brand engine oil are you using? I'm planning on using synthetic blend
Vdrive oil?
Transmission fluid?
I have located the order numbers for the fluids from indmar just curious if everyone uses their fluids
'18 mojo 400
Thanks!
07-23-2019, 11:44 PM #2
The most important detail is to use the correct viscosity and the correct rating. I believe the required rating for my 400 in an ‘18 Max is SN.
Sent from my iPhone using TapatalkLast edited by Boonejeepin; 07-24-2019 at 12:51 AM.
2018 Max with a little extra weight here and there
07-24-2019, 04:02 PM #3Senior Member
- Mar 2017
- Middle TN
- 232
My understanding is the zddp levels matter for the cats? What level should I be shooting for?
07-24-2019, 04:27 PM #4
07-24-2019, 06:38 PM #5Senior Member
- Mar 2017
- Middle TN
- 232
Where do you find the zddp levels that the different oils have? I've looked around but can't find any information from the manufacturers
07-24-2019, 08:33 PM #6
07-24-2019, 09:54 PM #7
https://mobiloil.com/~/media/amer/us...pecs-guide.pdf
Sent from my iPhone using Tapatalk2021 Supra SA 400
2018 Supra SA 400 (SOLD)
Michigan
07-25-2019, 11:04 AM #8Senior Member
- Mar 2017
- Middle TN
- 232
I use castrol in my vehicles with no issue. Thinking I might use the "ultraclean" blend they have. Ive sent an email to the company looking for the zddp levels. Im assuming they will be in the range they should be to keep the cats happy. Thoughts?
07-26-2019, 01:24 AM #9Junior Member
- Jul 2019
- India
- 1
