Results 1 to 10 of 11
Thread: Thermostat
    Jan 2007
    Manchester,MO
    Default Thermostat
    Where is the thermostat located on a 2006 LSV?
    Jan 2007
    Manchester,MO
    O.K. Either my question was so obvious that no one would answer me, or this is a part that never gets messed with. Just in case anyone is interested, the tstat is located in the tstat housing which is over the water pump on the rear of the engine. It has four hoses connected to it, two big and two small. I have not removed it yet, but I think you have to remove all four hoses then the three bolts that hold the housing.
    Feb 2006
    Birmingham
    I was planning on replacing mine this spring. Have you purchased a new thermostat and gasket or is there even a gasket?
    15 Mondo Surf Edition
    02 LSV - Traded In
    Jan 2007
    Manchester,MO
    No. There is actually nothing wrong with my tstat. I was doing research on winterization and someone said to remove tstat before running antifreeze through system. I just replaced my heater coil, and never want to do that again. In case you have a heater, just pulling the two hoses off will not get the water out of the coil.
    Feb 2007
    tacoma
    most chev engine thermostats come with a gasket whether you actually need them or not
    Dec 2006
    tally, fl
    thermostat on rear of engine? thats new to me..
    Mar 2004
    Martinsville,Indiana
    Probably a "V" drive.Back of boat,front of motor.Go easy on the Nube.
    John
    Dec 2006
    tally, fl
    oops...
    Aug 2004
    Lake Hickory, North Carolina
    Hey, if you don't know, it doesn't hurt to ask, right?
    B
    Dec 2006
    tally, fl
    way to learn & gain knowledge
  1. thermostat & no water from exhaust
    By VerityBob in forum Service & Repair
    Last Post: 04-27-2005, 09:16 PM
  2. Thermostat Temp.
    By wdf in forum Service & Repair
    Last Post: 06-26-2003, 10:06 PM
