Results 1 to 3 of 3
    Dec 2018
    Phoenix AZ
    Default Gravity III Forward Ballast Sac
    I have the 1180 bag in my 2006 front locker which isn’t vented from the factory. The bag has a fill and drain port at the rear and one drain up front. My question is can I flip the bag over and use that front drain as a vent? I notice a lot of air in the bag when filling.
    Apr 2013
    Knoxville TN
    That would probably work for filling, but I assume you would create another issue during draining.
    2018 Supra SL400
    Dec 2018
    Phoenix AZ
    It actually worked. The drain and fill on the back side are the same height. I filled the front bag and it only fills half way because there is no vent. Opened the drain up front and I was able to fill it all the way up. I can’t believe these things weren’t vented at the factory.
