Results 1 to 8 of 8
06-16-2019, 11:49 AM #1Junior Member
- Jun 2019
- Albuquerque, NM
- 19
V-drive water flowing out at drive shaft? Low oil pressure red light?
o, on another post I asked about getting water into my new (to me) Outback V in my driveway. Got that done, started right up, sounds great (like a kitty purring, as my neighbor said) but two things came up.
One, looking under the boat as it was idling, water is coming out of where the drive shaft exits the boat. At first I thought I thought it was a bad axle seal (and was really bummed). Thinking about it more, since I am putting water into the cooling system and not into the boat, the water must be coming out of the cooling system near the axle outlet. This led me to wonder (and hope) that it's by design, maybe to cool the bearing? Please tell me it's so. The water runs out at a pretty good clip. Should this be or do I have a problem?
Also, I ran it at low rpm, mostly an idle, and the "low oil pressure red light" was on which, I gather, is expected. I did rev it up very briefly to 2000-2500 rpm a couple of times and the light stayed on although it did flicker a little bit. I am guessing the system has to build a little pressure for the light to go off and does not go off immediately and am hoping that, on the lake and under a load it will go off. Here in NM it's 2 1/2 hours to the lake so I'd like to have an idea before running down there. Would those familiar with this agree that it's likely on the cusp of going off or should it go off immediately at a certain rpm (around 1500)?
Boat is new to me, purchased from another state but did have a very reputable boat shop do a full inspection of it back in December before delivery. It's a 2008 Outback V, factory ballast, wave plate, speed control.
My 3 daughters are really itchin to get out on the water so any input would be appreciated.
Thanks!
06-16-2019, 07:04 PM #2
Not really following you on the water issue..
Are you talking the low engine oil pressure light? If so, that should NEVER be on! If it is immediately shut the engine off and don’t run it until you determine the cause. What was the oil pressure gauge reading?
Hopefully this is a electrical issue and not an actual low oil pressure issue.
If your talking about the red light on the throttle housing, then go read the manual. It explains...
06-16-2019, 07:33 PM #3Junior Member
- Jun 2019
- Albuquerque, NM
- 19
Thanks for the reply. I am talking about the red light on the throttle housing. Oddly, I read every page of the owners manual, all 80 of them. Looking at it again I see it says to check the oil in V-drive, I thought it had said to check the engine. I ran it today and no red light at all. The oil pressure is good per the gauge.
The water issue I would like a little input on so I will try to clarify. I may have over complicated it in my description. It's fairly simple. When I am running the engine out of the water with a hose feeding the inlet side of the transmission, as one would expect, water exits the exhaust. At the same time, with it idling, I looked under the boat and quite a bit of water is also flowing out of where the axle or prop shaft exits the boat. Is this by design? I am now guessing it is since the only way for water to get to that location in this circumstance (there is no water leak into the transom) is for it to be piped or fed there somehow, probably to cool the bearing, but I would like to know for sure. I guess I would just very surprised to see the water flowing out of there as well as the exhaust.
Thanks for any input!
06-16-2019, 10:12 PM #4
Water dripping from shaft is normal and by design I believe. It is cooled by the water.
2019 Moomba Max "MOOMBAE"
2016 Yamaha AR192 - sold
06-18-2019, 11:09 AM #5Junior Member
- Jun 2019
- Albuquerque, NM
- 19
For anyone that has the same question or concern this is what I learned.
I ended up speaking with the mechanic that did the inspection. He is very knowledgeable on these boats and said thiat it has a dripless shaft water seal (I gather from the factory but I did not ask that) and does indeed have a line running to a nipple on the seal housing, beyond the seal, for water to cool the bearing and then flows out the shaft drive hole. I looked at pictures of the dripless shaft water seals and you can see the nipple for a hose to attach too. All good news to me. Again, just for someone that also has the same situation. Thanks for all replies!
06-19-2019, 09:56 AM #6
Yep, that’s from the dripless seal. Glad everything is working. I take it your V-Drive has the proper amount of oil? The light is not for engine oil pressure but for the V-Drive oil pressure and the light is the only thing that tells you that you have low oil pressure. My light goes out around 1000 rpm and all other times it’s in. You might have a bad switch. You can get them at skidm.
06-20-2019, 05:05 PM #7
Be careful engaging your drive while out of water. The cutlass bearing is not lubricated and this can cause premature wear.
99 Outback LS. Sold
06-20-2019, 05:54 PM #8
Yep, the light is supposed to be on under something like 1200 or so rpm in gear. My 2008 had a little placard around the vdrive light that stated this, but I don’t recall the exact rpm.
2018 Murder Max
