Results 1 to 9 of 9
    Aug 2018
    Default How to test swell tabs
    Anyone know how to, or If one can, engage or deploy the swell tabs when the boat is not moving, like on the trailer to test them? I'm trying to troubleshoot why my swell tabs don't work. I can do the center tab, but not sure about the swell tabs. 2015-17 Supra models
    Sent from my SM-G965U using Tapatalk
    Commerce Lake, MI
    You should be able to turn on the surf system to one side and it will instantly deploy the opposite tab.
    I.e. if you select surf left, it should deploy the right tab immediately.
    2017 Moomba Craz
    Aug 2018
    Thanks, have you done this while the boat is not moving? The warning states that the cruise must be active between 9-12mph.
    Quote Originally Posted by Boatlaunch View Post
    I was looking for this info too, thought the plate only moved after reaching a certain speed.
    There's a dealer section in the settings, I've been trying to guess the code on/off hoping it would have a diagnostic screen.
    2006 Moomba Mobius LSV - Sold
    Commerce Lake, MI
    On the Moombas it activates immediately and does not require a certain speed to deploy.
    2017 Moomba Craz
    Oct 2016
    Tims Ford Lake TN
    I'd guess the Supras are same, not sure: On my Mojo the actuators go through a start-up sequence of movement when the key goes to the run position. You don't have to even crank it while its on the trailer. Just have someone move the key while you watch on the ground.
    2016 Mojo Surf
    Raptor 400
    FAE
    Aug 2017
    I believe there is a dealer code that can get you into this mode. I don’t know it, but someone probably does?
    Aug 2018
    I found the problem. This breaker was off, so no power to some of the toggles, the swell plates, and the steering column cruise adjust. The swell plates do adjust now from the screen, with the boat on the trailer. I can't believe I didn't check this earlier.
    May 2018
    I recall during my dealer delivery, he showed me the breakers and said if anything stops working, check breakers first.
    Glad it was simple.
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
