Page 11 of 11 FirstFirst ... 91011
Results 101 to 106 of 106
  1. #101
    Mar 2021
    South Georgia
    Quote Originally Posted by TXSurf4 View Post
    Pretty sure yours does as well as I doubt they have changed that. The L shaped bags on the Mojo are pretty sweet as you only have to vent that bag but if you want to add on top of it under the seats you have to add new plumbing to piggy back off the rear bags where as on our Makais you just have to buy a larger bag for the subfloor bag and swap it out but then it is no longer subfloor lol.
    If so, that is an awesome way to add some easy weight!!!
    2021 Moomba Makai
  2. #102
    I moved more lead to the bow and got the pitch at 9-9.5 and increased speed to 11.3 and it was a huge difference in firmness. Doesn't feel soft anymore and I can actually pump against it! I did lose a noticeable amount of size in the form of height but it did lengthen out. I suspect now I just need more displacement if I want it bigger. Thank you so much for the help everyone.
    2021 Moomba Makai
    Minnesota
  3. #103
    Jan 2021
    Columbus, Ohio
    Quote Originally Posted by benny32 View Post
    Your suspension is spot on! Invite everyone you know to go to the lake. Need 6 adults minimum and have them sit where ever to achieve the same pitch, roll numbers. Once you see this though you will be spoiled on light crew days and start adding my bags to your boat. I had 10 out Saturday and the wave was a litter short (needed more bow) but it was and very large wave.
    2015 Moomba Mojo Surf Edition
    4,000lbs
    Manual Flow
  4. #104
    Oct 2018
    Hockley, Tx
    Ya no worries! Glad to hear it worked out. As far as the size you are spot on, just add more weight. Moving some lead to the bow and speeding up made the wave longer and firmer but sacrificed some height once you add some more weight you will find the sweet spot.
    2019 Makai
    Raptor 450 w/ 1.76 Trans
  5. #105
    Mar 2021
    South Georgia
    Got any pictures??
    2021 Moomba Makai
  6. #106
    Got any pictures??
    I'll try to grab some this weekend if the weather cooperates!
    2021 Moomba Makai
    Minnesota
