Results 1 to 10 of 12
Thread: Easy way to drain old gas?
06-05-2019, 11:42 AM #1Junior Member
- Oct 2018
- 6
I have a 2005 moomba outback and I need to drain the gas from it as it has been sitting for over a year in the tank. What is the easiest/fastest way to make sure to get it all out before putting new gas in?
06-05-2019, 11:46 AM #2
I would disconnect the fill hose from the tank and siphon out. Then flush with a gallon or so of fresh fuel and siphon that out. Dispose of the first part properly. Use the last gallon in the lawnmower.
06-05-2019, 11:54 AM #3
Not sure how it is on the 2005 but I was at my dealer this week to check my fuel pump for a recall on the grommet between the pump and tank and we pulled the floor up by removing 8 screws and then it was all right there seemed pretty easy to pull the pump out and just siphon it straight from the tank. Then I would follow the above suggestion with disposal and cleaning with a fresh gallon
Sent from my iPhone using Tapatalk2019 Makai
Raptor 450 w/ 1.76 Trans
06-05-2019, 05:47 PM #4
I hadn't started my GTO in several years with old gas in it, like 5+ years. Ran a little rough at startup, but was otherwise fine. You can siphon it out, but I wouldn't bother. YMMV.
She ain't pretty, but she can dance!
06-05-2019, 06:02 PM #5
Carbureted or fuel injection? Carbureted is easy as I did that twice a year.
SOLD
06-05-2019, 07:30 PM #6
How much in the tank? Seriously, id dump in a can of Stabil and run it like I stole it. Year old gas may be a little flat, but its not terminal.
06-05-2019, 10:59 PM #7Senior Member
- Aug 2011
- 2,522
2006 Moomba Mobius LSV - Sold
