Results 1 to 6 of 6
Thread: Ballast System Leaking
06-05-2019, 10:30 AM #1Junior Member
- May 2019
- 7
Hi Everyone,
I have a 2006 Moomba Outback V, the ballast system fills up and empties perfect but when have it off water continually comes through the lines, if i lift the line up high enough the water will stop. Does anyone know what causes this problem? Are the pumps bad or is it an o ring?
Thanks
Cameron
06-05-2019, 02:46 PM #2
It’s self siphoning. Add some anti siphon elbows to your overflow lines and it should stop. You can get them from Wakemakers.
06-06-2019, 11:44 AM #3
first off assuming you still have the old single pump and sprinkler valve setup? on top of the vdrive there should be a section of hard plastic sprinkler pipes and 3 valves with ballast hose going to each rear and the center locker bag.
if so is it filling on all 3 bags or just 1.
first place I would check would be the valves. they could be sticking partially open/closed.'06 Supra Launch 20SSV-gone but never forgotten
06-06-2019, 12:33 PM #4
06-06-2019, 10:33 PM #5Junior Member
- May 2019
- 7
Awesome thanks guys. I’m heckling the valves first thing tomorrow!! I’ll let you know what happens
08-15-2019, 01:10 PM #6Junior Member
- May 2019
- 7
So i have the old sprinkler system with the black on off valves and I replaced all 3 valves and 2 of the O rings, all set now!! thanks for your help. Each valve was only $33.00
