Results 1 to 3 of 3
Thread: Raw Water Pump
    Default Raw Water Pump
    Would any one be able to tell me what make the Raw Water Pump is on a 2004 XLV GG..
    I have noticed it has started to drip fairly badly when at idle and I believe the seal has probably gone. I am told it’s possible to buy a seal kit for these rather than complete replacement??
    Also what make it the ring gear on the flywheel?? Is it possible to replace the ring gear on the flywheel and not replace the whole thing..??
    Look forward to hearing your thoughts..
    Brian Raymond Guest
    It is a Johnson pump. There is a impeller repair kit available, it includes a impeller, gasket, and seal that installs in the back of the raw water pump. The Indmar part # for this kit is 495001, check with your dealer for pricing. The flywheel is only available as a 1 piece item, the ring seperately is not available. The Indmar part # for the flywheel is 551043. Hope this helps, keep us posted.
    Dec 2006
    tally, fl
    I have found that the folks at skidim.com are ver helpful and knowledgable with repairs/parts. good prices too. ck-em-out !
  1. Raw Water Pump Removal
    By dtlaine in forum Service & Repair
    Last Post: 07-10-2008, 04:11 PM
  2. Water Pump Leak
    By tlrowe in forum Service & Repair
    Last Post: 08-14-2007, 07:52 AM
  3. water pump wobble
    By james yarosz in forum Service & Repair
    Last Post: 06-15-2003, 10:30 PM
  4. Indmar Water Pump
    By moombamania in forum Boat Owners
    Last Post: 06-12-2003, 11:04 PM
  5. water pump
    By Mainemoomba in forum General Chat
    Last Post: 06-09-2003, 10:05 PM
