Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
    Apr 2018
    Texas
    What plugs were in cylinders 3 and 5?
    The blue ones are newer and weíre on the exhaust side. The intake plugs are the original ones. Each one had one of each. I swapped coil and plug wire from 3 to 1 if it misfires again itíll be easier to just change the coil packs.
    Anyone know how to clear the check engine light. Sure be nice if there was a obd 2 port some where hidden
    2015 Mojo
    2005 Yamaha at-230 sold
    2012 Ram 2500 tow rig
    Aug 2018
    Conifer, CO
    On a car having the negative terminal disconnected for several hours (18 - 24) will usually clear the code. You can also disconnect BOTH terminals form the battery and then touch the terminals on the WIRES to each other. Be careful and don't create a direct short. Use a volt meter to be sure the wires dont have any voltage.
    She ain't pretty, but she can dance!
    Apr 2018
    Texas
    Quote Originally Posted by 1967Goat View Post
    On the newer cars itíll still store the faults in the memory even if you do a capacitive discharge. But it is ford guess Iíll give it hell and see what happens
    2015 Mojo
