Results 1 to 3 of 3
Thread: Rocker Switches
    Oct 2016
    Livingston, Texas
    Default Rocker Switches
    My bilge and acc rocker switch caps (or whatever you call them) are falling off. So is it the switch body or the cap that wears out and is there a fix or do they have to be replaced? Neither of them looks obviously worn and I'm reluctant to pull another off to compare thinking it would do the same. 03 22V.
    03 Launch 22V
    3) 800lb sacks, Perfect Pass
    Fusion head, JL amps, Wet Sounds Interior/Tower Speakers, 10" Sub
    "Anyone have a stainless steel magnet?"
    Oct 2016
    Livingston, Texas
    Ok, I've learned the switch cover is called an actuator, the switch is the body and there's a tool for removing the actuator. I ordered a couple of replacement actuators to replace the loose ones in hope that is what is the worn part.
    Oct 2010
    Lake Wylie NC Area
    If the switch body tabs are not broken, you can just replace the actuators. OTRATTW.com
