Results 1 to 3 of 3
Thread: Draining timing
    Oct 2015
    So. Cal.
    Default Draining timing
    It may be posted on here, but I didn't see it. How do you reset the timer to fill and drain correctly? We had a fitting failure and had to interrupt the process. Now I'd like to reset so they fill and drain correctly.
    Nov 2016
    Knoxville, TN
    User settings then look for ballast option.
    2011 Sea-Doo Wake 155
    2015 Mojo Surf, sold...2013 Axis A22 Recon Edition, sold...2010 Axis A22, sold...2007 Maxum 180sr3, sold
    Dec 2018
    Dublin, Ohio
    On mine you have to select the value (empty/full) then hit reset before leaving the screen or it won’t work.
    2019 Craz
