Results 11 to 20 of 20
Thread: Enzo
05-14-2019, 11:11 AM #11Junior Member
- Jul 2018
- Abingdon Va
- 27
did you mount the L reinforcement brackets to the base of the rear locker with screws im assuming
05-14-2019, 11:14 AM #122017 Moomba Craz Surf Edition
05-14-2019, 12:38 PM #13Junior Member
- Jul 2018
- Abingdon Va
- 27
Ok so all I need is reinforcement on the bottom of the panels and all my fittings and hose is correct in the original post?
05-14-2019, 01:16 PM #14Senior Member
- Sep 2017
- 232
Curious if anyone has ran Enzo Bags in a Mondo. I have the ExactFit 1140s in mine right now...and they probably get ~1000lbs in them. Just curious if the Enzos would even fit.
2022 SA450
2019 Mojo
2017 Mondo - SOLD
05-14-2019, 02:50 PM #15
05-14-2019, 04:28 PM #16Junior Member
- Jul 2018
- Abingdon Va
- 27
[QUOT goingE=RC_Hinojosa;340537]You'll probably need more fittings than your 650s currently have. Can you share a pic to confirm?
Sent from my Note9 using Tapatalk[/QUOTE]
I was going to possibly use my old
Bags as extras
05-19-2019, 10:43 AM #17
I'd say just try the Enzo's first and see how it goes. Using old bags on seats is not practical as they are cumbersome and inconvenient and take up valuable seating space. It also looks, should I say, ghetto, on such a nice boat. I like everything to look nice, clean, like custom. As if they weren't even there, until you lift the rear locker cushions. I'd give lead bags a consideration, in fact, I'm pondering about an extra 600 lbs. But, gotta pace myself. Just upgraded the surf tabs this year and need to replace the depth finder.
BTW, the surf tabs are a must. Love them. It really cleaned up the goofy side wave too.2020 Supra SL 400
2015 Moomba Mojo(Sold)
2018 Yamaha Waverunner(Just to fool around)
2018 F150 Lariat
sport edition, 3.5lt ecoboost
05-20-2019, 11:19 AM #18Junior Member
- Jul 2018
- Abingdon Va
- 27
05-20-2019, 06:36 PM #19
No, ballast weight in our boats is sufficient around 1000lbs. You, as do I, have the in bow sac (IBS). The horseshoe shape ballast bag under bow seats. Just make sure that when you are filling the IBS bag, you go up front and open the vent to let air out of the sac. Otherwise you will see the front sac is full, tense, but its all air unless you release the air. I usually will remove one of the top plugs and let out air until I see water coming out and then replace the plug. Otherwise you loose a lot of weight. I find if the front hard tank and IBS are full, it is plenty of weight.
That being said, if I add another 600lbs of lead eventually, I would distribute the weight ~40/60, bow and stern.2020 Supra SL 400
2018 F150 Lariat
05-22-2019, 10:42 PM #20Junior Member
- Jul 2018
- Abingdon Va
- 27
