Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    Default Fuel Pump has no Power
    07 LSV with the Indmar 325. Was running great and then wouldn't start. Starter runs fine but the fuel pump isn't running. Checked the safety lanyard, all the fuses and relays that I could find. Unplugged the fuel pump and checked for power at the connector and there is none with the key on. When you turn the key, the perfect pass comes on and you hear the beep and all the lights and ballast pumps work, but the fuel pump never runs.
    I read through the similar thread from 5 years ago and tried everything in there, but still can't get power to the fuel pump.
    Any help or ideas will be greatly appreciated.
    2007 LSV
    May 2013
    Did you try the red breaker that's next to the ECU?
    I just rewired my fuel pump harness, because I found that every so often I was getting a short and it wasn't priming on key start...
    www.TraysonsToybox.com
    Feb 2003
    idaho
    Happened to my mobius, it was the oil pressure switch. I wired around it and never got around to fixing it. If their is no oil pressure the fuel pump doesn’t run so you can’t run your engine dry of oil.
    2005 XLV
    gravity 3
    perfect pass
    Commerce Lake, MI
    Replace the oil pressure switch that the fuel pump gets the signal from.
    2017 Moomba Craz
    OK... Where is this oil pressure switch? I did check the breaker by the ECU.
    Also, where is the low pressure fuel pump located? I think I was only looking at the high pressure pump.
    2007 LSV
    Commerce Lake, MI
    It’s in the valley between the heads and the back of the engine. You can trace the power wire back from the fuel pump to it.
    Looks like this, although not necessarily on a T. If you find it you can jump the two wires and see if that kicks the fuel pump on with the ignition on.
    https://forums.iboats.com/filedata/f...2&d=1400632031
    2017 Moomba Craz
    May 2013
    Quote Originally Posted by ABC View Post
    Low pressure pump looks like this:
    High pressure pump looks like this:
    may or may not have the black rubber boot around it.
    Just remember there will be no power to these with the key in the on position. When you first turn the key on the high pressure one should see voltage for a few seconds. You need to test with the key in the start position.
    2006 Moomba Mobius LSV - Sold
    May 2013
    Which pump is the one that you hear with that characteristic BUZZ as it primes on key ON?
    Also, the wire harness for the fuel pumps has the positive and negative for both pumps coming from the exact same leads on the harness. So if the LP pump is getting voltage, the HP pump has to likewise be getting voltage.
    The black one makes the buzzzz noise with the key turned on the first time.
    The round one makes more of a clunk clunk and usually only runs when the key is in the start position and when the boat is running. Think these were added sometimes to help with vapor lock, how it's installed may be different.
    I would trace the wires all the way till you get good ground and 12v with the key in the starting position. My guess there's a relay, when you first turn the boat to on the pump should prime, then run again once the boat is starting or running.
