Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Oct 2016
    Wisconsin
    Default Boat mate trailer and brakes backing up
    I just got my 2019 mondo, and what i noticed is anytime i am backing up the trailer brakes go on unless i am level going straight. But if i turn the wheel or am on a hill the brakes activate.
    I used the key to lock them out but is this normal? i am able to back up level going straight. I have the round connector plugged into my truck, the barrel connector and all fuses are good.
    2019 Mondo - no longer on order. Took delivery!
    May 2018
    If you are plugged in the solenoid should deactivate when your reverse lights power up.
    Sounds like your connector is not working or wired properly.
    Henderson, NV
    do you have a solenoid on your trailer? not all trailers come with an electric reverse lockout.
    Oct 2016
    Wisconsin
    I don't know. its a brand new 2019 from boatmate. It has the lockout which i used and inserted the key.
    Feb 2017
    Colorado
    You shouldnt have to use the key... I would start with your truck wiring.
    Jan 2018
    Lexington, KY
    My new 2018 was doing this when i brought it home last year. I found a loose ground on the solenoid under the tongue of the trailer. It was one little Phillips head screw with a ring terminal on it.
    if that's not it, check for 12v between pin 7 and 2 on your truck when in reverse.
    2018 Moomba Craz | Autowake 2.0, Zero-Off, G6 Pumps | Captain Blue/Dark Graphite/Silver Flake | Enzos + Lead
    Apr 2013
    Knoxville TN
    Good pic/attachment
    2007 Supra SSV 22'
    Feb 2017
    Ontario
    No too sure what wiring your trailer has on it, but my 2017 Boatmate trailer came with a 6 pin straight connector that plugs in to a 6 straight to 7 round pin adapter then in the 7 pin receiver on my truck.
    I turn on my headlights manually (on auto does not work) to disengage the trailer brakes when backing up.
    Different.... but it works...
    2017 Moomba Mondo
    2000 Moomba Kamberra > Traded
    Jan 2018
    Lexington, KY
    Quote Originally Posted by korey View Post
    Between pin 7 and ONE. Not 2. I fat fingered that... don't let the pin for "trailer brakes" confuse you. That's for electric brakes like on campers and horse trailers.
    Oct 2016
    Wisconsin
    I will check this, thanks for the graphic. My truck is brand new as well and tow many trailers, some with brakes and never has been a problem.
