Results 1 to 10 of 12
Thread: AMP Power Kit
    Jan 2013
    Northeast, PA
    Default AMP Power Kit
    I bought a new Fusion Marine AMP for Kicker KMT674 speakers. My question is do you recommend a marine AMP power kit or is a normal car audio AMP power kit ok?
    Mike
    Sent from my SM-N950U using Tapatalk
    2007 Moomba Outback V
    Oct 2010
    Lake Wylie NC Area
    I suggest you go A-La-Carte. Figure what you need and the estimated lengths, then purchase. A typical car audio amp kit is going to likely come with 20ft of B+, 2Ft B-, 20 foots rca and a cheap fuse holder. The crimp on open toed battery ends are poor. Your Fusion dealer or the Fusion Tech support should be able to assist with proper cable gauge and circuit protection amperage.
    Jan 2013
    Northeast, PA
    So, I was not looking to break the bank on upgrading my tower speakers. I got a good deal on like new Kicker KMT674 tower speakers but needed an AMP. I contacted Crutchfield and they gave me 3 options for AMP'S Wetsounds, JL and Fusion. I decided to buy the Fusion AMP from BoatID which was ~$90 cheaper than Crutchfield. Crutchfield recommended a 4 gauge / 100 amp power kit. The first speicalist recommended a $80 kit and the 2nd speicalist recommended a $160 marine power kit. I know the AMP I currently have is not a marine power kit. I don't want to over spend on something that is not neccessary.
    Oct 2010
    Lake Wylie NC Area
    Thats why I suggest piecing it together with the proper components for YOUR install, rather then someones idea of a pre-package "kit". Odd are you will end up with too much of something and something else too short. Any dollar spent there is overspending.
    Oct 2016
    Tims Ford Lake TN
    Most forum members were recommending knukonceptz online. That is the I went for install on mine 2 years ago.
    2016 Mojo Surf
    Raptor 400
    1100 rear bags / 500 IBS / 600 LeadWake
    Exile amps/tower - Kicker in-boat
    FAE
    Oct 2010
    Lake Wylie NC Area
    Just steer clear of their oversized gauge trash.
    Henderson, NV
    Quote Originally Posted by BigOrange View Post
    I've used Knukoncepts for the last 2 boats and 3 cars. decent value for the buck.
    Nov 2009
    Stillwater, Oklahoma
    Quote Originally Posted by Gabbyg88 View Post
    This is very interesting that Crutchfield would recommend an amp other than Kicker when you are powering Kicker speakers. The KXMA4002 is a perfect choice for powering the KMT674.
    Other than that I agree with MLA that you are best served buying A La Carte. A car amp kit usually won't do it by itself as the ground wire is too short usually.
    Phil
    Kicker
    May 2013
    Vancouver WA
    I would add that you should look for Oxygen Free Copper (OFC) wiring for the marine environment, rather than the Copper Clad Aluminum (CCA) that most of the value offerings are.
    www.TraysonsToybox.com
    Jan 2013
    Northeast, PA
    I just checked the Kicker AMP kit I bought on Amazon and it is OFC. Got lucky on that one.
