Results 1 to 10 of 16
    Sep 2017
    Default Acme 1235 - 2017 Mondo
    Hey all,
    I have an OJ 945 - 15x13 that came with my 17 Mondo. I am running between 3500-4100lbs weight dependent upon the size of crew.
    I have the ability to get an ACME 1235 for super cheap...and curious if anyone is running the 1235 on a Mondo of similar weight and year. This would be 100% just a spare and weekend saver and don't expect it to run as well as my 945...but just curious on feedback.
    My limited research tells me it should work OK...but more than likely up my RPMs if I am running it with all the weight.
    Thanks!
    2022 SA450
    2019 Mojo
    2017 Mondo - SOLD
    Nov 2016
    Knoxville, TN
    Yes, snag it. That's what I had on the Mojo running as much or more weight than you, it was great! Lower rpms while cruising and wakeboarding. Surfed great as well.
    2011 Sea-Doo Wake 155
    Oct 2016
    Tims Ford Lake TN
    Quote Originally Posted by KnoxMojo View Post
    Knox, what should I target for surf and wake rpms at 3500 to 4000 lbs on the Mojo? I think I have the factory surf prop and never have any probs getting to plane but worried I’m pushing too many rpms at wake speeds.
    2016 Mojo Surf
    Raptor 400
    1100 rear bags / 500 IBS / 600 LeadWake
    Exile amps/tower - Kicker in-boat
    FAE
    Nov 2016
    Knoxville, TN
    Quote Originally Posted by BigOrange View Post
    If I remember, I ran 3500 pounds wakeboarding and 4100 surfing plus crew in our Mojo. Wakeboarding at 22-24, it was running around 3400 rpms. Empty weight, I could cruise all day in the low to mid 30s at around those same rpms. Surfing was low to mid 3k rpms as well. It did take it a few to get on plane at wake speeds with 6 or more people, but once up, it was great. The new boat has the 15x13, it runs too high for my tastes and cruising in the high 20s at around 3500 rpms. I will be swapping it out soon.
    Henderson, NV
    1235 is the prop I upgraded on the supra and what my last and current boat came with. I would not hesitate to grab it and if it was me I'd swap out the oj and use that for the spare.
    Oct 2016
    Tims Ford Lake TN
    Thanks for the input @KnoxMojo
    2016 Mojo Surf
    Raptor 400
    FAE
    Nov 2016
    Knoxville, TN
    Yes sir...Sandm, it really is a great all around prop. I'm going to try a 15x14 on the SA to see how it does.
    Aug 2017
    I had the 1235 on my 14 Mondo, swapped it out for 2419, 15x12. Boat is much happier with the 2419. I'd run what you have, 1235 would be a good backup prop.
    2019 Supra SL450
    Oct 2010
    Lake Wylie NC Area
    Comparing a 15 x 13 to a 14.5 x 14.25, the 1235 would certainly be the less aggressive prop. That does make it a bad prop though. if the price is right, a 1235 would be a good spare to have.
    Sep 2015
    Conroe, TX
    What’s on your SA now? I’m running the 2775 15x12.5 on my 400 and I run outta prop when I’m loaded down. With the extra 600# of lead I can definitely feel it.
    I’m about to order a 2419. Most aggressive they make as far as I know.
    Overkill is underrated
    2006 Supra 24SSV Gravity Games- traded but never forgotten
    2017 Supra SA 400
