Results 1 to 2 of 2
Thread: Port Side Ballast
01-17-2007, 03:07 PM #1Member
- Nov 2006
- 39
Port Side Ballast
My port side Ballast bag has suddenly stoped filling. You can hear the pump working and trying to fill the bag but no water.
I was just wondering If there is a section from the water pick up to the pump that is a common blockage area..?
01-17-2007, 03:25 PM #2
There should only be one fill pump on the boat. Check the electroniic valve on the plumbing tree on top of the transmission. When you flip the switch to fill the port bag, the fill pump starts running and the valve that leads to the port bag will open (you should hear a loud click coming from the valve...get somone to flip the switch while you hold your ear near the valve.). Since these are electronically actuated they will eventually stop working. I seem to remember someone on the board replaced the actuator with sprinkler parts from Lowes or Home Depot. Even though the sprinkler parts are 24 volt, the 12 volt system on the boat will still activate the actuator. Hope this helps!!!
15 Mondo Surf Edition
02 LSV - Traded In
amps under dash on drivers side
By NC05LSV in forum General ChatReplies: 0Last Post: 08-19-2007, 04:24 PM -
Boat side cupholders
By MobiusV01 in forum General ChatReplies: 0Last Post: 07-11-2005, 11:27 PM -
XLV -Wake size/shape both side equal for wakesurfing?
By kendal in forum General ChatReplies: 1Last Post: 03-30-2004, 09:47 AM
