Results 1 to 6 of 6
03-31-2019, 12:39 PM #1Junior Member
- Mar 2018
- Hoover, AL
- 4
Hard Start when Cold - 08 Mobius LSV
Bought boat last year. Has Indmar 325 hp 5.7 engine. Runs great except difficult to start when cold. Sometimes have to use starter fluid, and it will fire immediately. Once it cranks, it will crank immediately after. Fuel pressure is a constant 60-62 psi at the rail. New Iridium plugs, distributor cap and fuel filter were installed. Engine has 2 fuel pump set up. Curious as to if others have experienced these issues and the solution.
03-31-2019, 01:33 PM #2Member
- Aug 2016
- 98
my 08 has a 340 cat engine and it takes like 5 sec to crank and start , may be leaky injector or regulator bleeding down
03-31-2019, 03:41 PM #3Junior Member
- Mar 2018
- Hoover, AL
- 4
03-31-2019, 08:20 PM #4
Is the Fuel Pressure 60 BEFORE you try a cold start?
04 LSV
04-04-2019, 07:22 AM #5Junior Member
- Mar 2018
- Hoover, AL
- 4
It’s been since last fall since I worked on the boat, but my recollection is th fuel pressure was constant and at or above 60 psi. Really thought the fuel pump was the issue, but based upon pressure gauge readings it is good. On a separate note one day could not get the boat to run well at all - inconsistent rpm, surging, etc. Found that one of the booster fuel pump wires had come loose. Put it back on and it ran well. Generally, once it cranks and runs initially it runs great.
02-03-2020, 11:08 PM #6Junior Member
- Mar 2018
- Hoover, AL
- 4
Wanted to provide an update to this post. After replacing the coolant temp sensor without any change, was working on the boat late in the season and found the problem. The ignition switch was bad. It got to where it was not only difficult to start cold, but sometimes when warm as well. Found a new ignition switch for less than $20. Boat runs like a champ.
Also, have a good friend that had a similar issue. His is a 2006 with same 325 Assault. His boat would just cut out and sputter when running. Acted like water in fuel. Once the key switch was replaced his ran well also.
Thoughts others would be interested in our findings.
