Results 1 to 8 of 8
Thread: Should I change my oil?
03-27-2019, 10:53 PM #1
Last season I was only able to go out 3 times in my boat because of my truck being stolen. I did a oil change before the first outing. So I'm wondering if i should change it after it sitting in storage since October?
I put less than 15 hours on it too.2008 Moomba Mobius LSV.
325 ASSAULT
03-28-2019, 09:42 AM #2
You are probably fine, but I would change it each year. Oil changes are cheap.
Most of the materials from Indmar probably say every 50 hours, not by months.
Oil does not go bad in 1 year from sitting there, yes it breaks down with starts/stops. Oil would be likely be diluted by water vapor (combustion by-product ) - same as low mile cars.
On the older hot rods I've owned, I was more concerned about the 'cold-starts' and the internal damage done by sitting for 1-2 years. Thus we spray a little oil in each cylinder before starting the first time.2018 Supra SL400
03-28-2019, 08:45 PM #3
I would not
03-31-2019, 11:58 AM #4
I have a 2003 outback ls.Since the kids grew up I only put 15 to 20 hours a year on it.Ivebeen going two years between oil changes and have no issues.I do always fog the motor when I winterize.(no cats) The grandkids are getting bigger so Ill probally start to use the boat more!
jy
04-02-2019, 11:03 AM #5
I would change it, I'm a believer in doing it every year regardless of how little it gets used. It's cheap insurance and easy to do.
Scott
2021 Craz
1997 Sea Ray 190
04-02-2019, 05:02 PM #6
The subject of oil is always a giant black hole of opinions.
Instead of giving my opinion, I would rather give you a constructive option.
Blackstone oil analysis.
https://www.blackstone-labs.com/?ses...ez045%29%29%2F
If you want factual scientific information about engine oils, use this service.
Education so that you can make data driven decisions.
2018 Supra SA 400 (SOLD)
Michigan
04-02-2019, 05:58 PM #7Member
- Aug 2016
- 98
so like 6 qts of 15-40 and a filter is like 30$ just change it. Just remember its a truck engine that is always under extreme load and in the worst wet conditions. I look at it this way, is your summer not worth a 30$ oil change?
04-02-2019, 06:31 PM #8
The 3000 mile oil change is one of the biggest man scams in history.
With a quality full syn and good filtration , 25k Miles is very doable.
Ask my 248k mile truck on less than 10 oil changes.
Data is available if you want, otherwise just throw money at it.
Michigan
