Results 1 to 8 of 8
    Aug 2015
    Default Should I change my oil?
    Last season I was only able to go out 3 times in my boat because of my truck being stolen. I did a oil change before the first outing. So I'm wondering if i should change it after it sitting in storage since October?
    I put less than 15 hours on it too.
    2008 Moomba Mobius LSV.
    325 ASSAULT
    Apr 2013
    Knoxville TN
    You are probably fine, but I would change it each year. Oil changes are cheap.
    Most of the materials from Indmar probably say every 50 hours, not by months.
    Oil does not go bad in 1 year from sitting there, yes it breaks down with starts/stops. Oil would be likely be diluted by water vapor (combustion by-product ) - same as low mile cars.
    On the older hot rods I've owned, I was more concerned about the 'cold-starts' and the internal damage done by sitting for 1-2 years. Thus we spray a little oil in each cylinder before starting the first time.
    2018 Supra SL400
    I would not
    May 2003
    south east michigan
    I have a 2003 outback ls.Since the kids grew up I only put 15 to 20 hours a year on it.Ivebeen going two years between oil changes and have no issues.I do always fog the motor when I winterize.(no cats) The grandkids are getting bigger so Ill probally start to use the boat more!
    jy
    Salt Lake City, Utah
    I would change it, I'm a believer in doing it every year regardless of how little it gets used. It's cheap insurance and easy to do.
    Scott
    2021 Craz
    1997 Sea Ray 190
    May 2018
    The subject of oil is always a giant black hole of opinions.
    Instead of giving my opinion, I would rather give you a constructive option.
    Blackstone oil analysis.
    https://www.blackstone-labs.com/?ses...ez045%29%29%2F
    If you want factual scientific information about engine oils, use this service.
    Education so that you can make data driven decisions.
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
    so like 6 qts of 15-40 and a filter is like 30$ just change it. Just remember its a truck engine that is always under extreme load and in the worst wet conditions. I look at it this way, is your summer not worth a 30$ oil change?
    May 2018
    The 3000 mile oil change is one of the biggest man scams in history.
    With a quality full syn and good filtration , 25k Miles is very doable.
    Ask my 248k mile truck on less than 10 oil changes.
    Data is available if you want, otherwise just throw money at it.
    2021 Supra SA 400
    Michigan
