Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 67
  1. #21
    Aug 2011
    Commerce Lake, MI
    Nice upgrades. Wish they were backwards compatible.
    2017 Moomba Craz
  2. #22
    Apr 2012
    Wake Forest, NC
    Quote Originally Posted by DFTR Josh View Post
    The fitting you see does nothing for the sensors. The are a special fitting that allows air out but not the water, self burping bag. How quick do the let air out I'm not sure but I love the idea.
    I wonder if/when we will see this type of vent available from wakemakers?
    2018 Murder Max
    2008 Outback V-Bought new; sold in 2018
  3. #23
    Jul 2011
    Murrieta, CA
    Quote Originally Posted by z28ke View Post
    I would bet there is a patent. But it would be cool to upgrade.
    2018 Max with a little extra weight here and there
  4. #24
    Apr 2012
    Wake Forest, NC
    Quote Originally Posted by Boonejeepin View Post
    My thoughts exactly
    2018 Murder Max
  5. #25
    Quote Originally Posted by Stazi View Post
    I think I remember hearing that for the mondo, craz, and mojo they are backwards compatible
  6. #26
    Aug 2011
    Commerce Lake, MI
    I have a 2017. The software won’t support it.
    2017 Moomba Craz
  7. #27
    Apr 2002
    Hey guys!! Sorry but I have been swamped lately working on the new stuff. To answer a few questions, the parts and technology are partially backwards compatible. When I say "partially", I mean you would have to have a boat that is at least 2017 and has the color 480 screen and AutoWake. So a 2017 Craz with 480 screen and Autowake can be upgraded to add the new "ballast sensors". As Josh said, the boats with the 480 screen (2019 Helix and Max) use flow sensors. We did this on purpose so that you could add the flow sensors to older boats. We have a parts kit that includes a full harness and 3 flow sensors. These sensors clip in the vent line already in the boat and then sees the water that tries to vent out the hose already in the boat. It actually is a pretty easy install and really improves the accuracy of the ballast. And as Josh says, keeps the boat from only bilging out water you don't want in the boat and NOT putting extra pressure on the bags in the boat. As some of you have found, if you overfill the bags too much and too long, sometimes the fittings go bad. Also, since this clips on the vent side, you can use any size bag for this install.
    On the 2019 models, we work closely with wakemakers and they have added the correct vent locations and even made an adapter to use our new vented fittings on the top of their custom bags. It is really cool and allows you to use the new technology on custom bags. You just have to make sure you are ordering bags for the correct year.
    Hope that helps! I will try and check on this forum later but might be a few days. Trying to get the new stuff rolling as well....
    Matt Brown
    Product Development Manager
  8. #28
    Apr 2002
    I forgot to mention, it does require the software update also. But you can put the 2019 software on the 2017 models if they have the 480 color screen....
    Matt Brown
  9. #29
    May 2018
    Goose. Does this “kit” work on 2017+ Supra’s?
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
  10. #30
    Aug 2011
    Commerce Lake, MI
    Quote Originally Posted by goose View Post
    Ok. Can we get the 2019 patch, please?
    2017 Moomba Craz
