Results 11 to 14 of 14
Thread: Boat speed while filling ballast
01-10-2019, 04:11 PM #11
I think brokepilot was referring to filling with the engine not running (which I never do because I always select either battery 1 or battery 2 - never both), so coming up this short on the fill makes sense.
2018 Murder Max
2008 Outback V-Bought new; sold in 2018
01-10-2019, 04:40 PM #12
The OP's opening statement
I know running above idle helps increase the voltage to the pumps
01-10-2019, 09:27 PM #13Senior Member
- Oct 2013
- Ft. Collins, CO
- 688
This isn't a problem. (As long as the intakes are in the water) Actually, moving water has a higher relative pressure which would make the pump more efficient, if anything, but I doubt it'd be in any significant way. The biggest gain is the higher voltage 14V vs. 12V, so long as the engine is turning enough to keep it up, it's all the same (I have to turn >1500rpm to keep the voltage above 13V with 3 pumps running)
1989 Sanger Skier DX - sold
01-10-2019, 11:53 PM #14
Yea, I misread the op’s post. But, there is a noticeable difference in the pump sound and I’d imagine put out just over idle. At least in my SA. Just at idle I can hear them whine and as soon as you add throttle they jump up too. Is the flow different? Maybe, probly not enough to notice.
Just set your timers for true neutral gear idle and then any amount of water over that is pumped out anyway. No sense in wasting extra gas if you’re sitting.Overkill is underrated
2006 Supra 24SSV Gravity Games- traded but never forgotten
2017 Supra SA 400
