Results 1 to 10 of 14
    Default Boat speed while filling ballast
    Has anyone figured out the highest boat speed that still allows the ballast pump intakes to draw the maximum amount of water?
    I know running above idle helps increase the voltage to the pumps and thus helps filling, but not sure at what speed the water starts flowing too quickly past the inlets to pump properly.
    2017 Moomba Helix
    May 2016
    Fargo, ND
    My dealer says 10mph
    2016 Mojo
    May 2016
    Fargo, ND
    I typically run around 5mph
    2016 Mojo
    I wonder how this works with autowake. You can always push the button at the base of the throttle to give it gas out of gear to pump up that voltage
    Aug 2017
    I fill under all speeds depending on what is going on...
    Oct 2010
    Lake Wylie NC Area
    True in theory, but likely making a difference measured in seconds.
    You can also put the shifter in neutral and bring the throttle just off idle if you need.
    Sep 2015
    Conroe, TX
    On my SA it’s actually a bigger difference than you’d think. And having bigger bags just amplified the issue.
    If I’m filling with the motor off I come up short by a couple hundred pounds by the timers with the Enzo bags. The nose usually takes an extra 2-3 hits of the switch (60 sec each) to finish it off if I’m going for 100% full.
    I usually fill with it running. And I’ve had them filling while cruising around 20-22mph., doesn’t seem to care.
    Overkill is underrated
    2006 Supra 24SSV Gravity Games- traded but never forgotten
    2017 Supra SA 400
    With Autowake and the 6 pump ballast system I fill at full speed or what ever speed we happen to be going at the time.
    2018 Supra SL550 with 850lbs of lead wake
    2017 Supra SA400 (Sold)
    2021 GMC Denali 2500
    Soulcraft Vodoo
    Soulcraft Jordi Pro
    Soulcraft Super AV
    Phase Five Matrix
    Aug 2017
    Quote Originally Posted by Prospersigman View Post
    Yep—same. It only takes 7 min or so anyway.
    Oct 2010
    Lake Wylie NC Area
    Quote Originally Posted by Broke Pilot View Post
    Obviously a larger sac takes longer to fill, regardless of voltage to the pump. I do not think pump flow is linear to voltage by design, but close enough. The difference between engine idle and engine off idle voltage, could be as little as 5%. So roughly .5 GPM, or 4 lb in 60 seconds.
    Id have to think hard, if this gain was worth revving my engine for that duration.
