Results 1 to 8 of 8
    Dec 2018
    Default Need a little help from someone with the 6.2 Raptor 400
    Hope this doesn't rub anyone the wrong way, but I need a bit of assistance.. I am doing a restoration on a 1975 Mako center console. I managed to pick up an Indmar Raptor 400 that's basically brand new, originally was in a moomba craz. I need to know a couple of things as far as the wiring goes, and there's no info I can find anywhere. If someone can help, that would be great. I'll just list my questions below:
    1. At the transmission end of the motor, there are two connectors, both two wires each. I am assuming it's fuel pump, but why are there two and which is which?
    2. The wiring diagram I have references a "paddle" which I'm assuming is a speed sensor wheel. Where does it connect to the system?
    3. If you take the cover off, right on top by the throttle body is a two pin connector, not a cable but a plug-in connector, right on top not far from the flame arrestor. What plugs in there?
    That's what I have right now. I may have a couple more if this proves fruitful. Thank you in advance.
    Dec 2018
    Default added some pictures
    Here's a couple pics of what I'm talking about.
    First, the connection on top of the motor by the throttle body.
    Next, the two wires I was referring to that appear to be for fuel pump(s). You can also see that one of these connects to a sensor right above the fuel pump... the second picture is a closeup of that sensor. Just trying to figure out how to set up my fuel delivery system.
    Contact indmar, they are pretty good at responding to tech questions.
    2006 Moomba Mobius LSV - Sold
    Dec 2018
    That's the thing.... not to me, they aren't. They seem like they are almost offended that I'm putting the motor in a non-wakeboarding boat. I literally can't get him to tell me which wire is which of the two connectors.
    That sucks, if I ask a specific question they've answered it, but haven't been successful in getting diagrams or parts lists from them. It's like pulling teeth. I've contacted skiers choice for wiring diagrams, just say you have a Craz and need the engine wiring diagram.
    Dec 2018
    Yeah, no luck there. If anyone can answer my question, at least the one about the fuel pump wires, that would be great.
    Not till may.. Sorry
    Forgot I had this..has some wiring info
    https://drive.google.com/file/d/1Pbz...w?usp=drivesdk
