Results 11 to 20 of 24
12-16-2018, 02:41 PM #11Senior Member
- Oct 2013
- Ft. Collins, CO
- 688
Yes, the cans would have to be elevated. We put a towel on the sundeck and then set the can up there. It works great. I started with the shaker siphon mentioned above and it works great. It's a game changer - I will never pour fuel cans again. But then... I learned about this: https://www.turbosiphon.com/ and it is amazingly fast. I only wish they had a small diameter nozzle on the end so that it could fit in normal automotive fillers - I need to do my own mod.
1989 Sanger Skier DX - sold
12-16-2018, 07:27 PM #12
Get a fuel pump, put on a power connector and a couple of hoses. I do in situ fueling of my motor home where I may be pumping 40 gallons at a time.
https://www.amazon.com/CarBole-Perfo...tive+fuel+pump1998 Mobius
SOLD
12-16-2018, 11:09 PM #13
12-17-2018, 05:45 PM #14Member
- May 2018
- Little Rock, AR
- 35
12-17-2018, 07:52 PM #15
Portable gas tank recommendations
Isn’t pulling the boat out and going to the gas station easier? Than lugging 13 5 gallon jugs?
Or just get a transfer tank for your pick up bed.
Most start at 36 gallons.
Sent from my iPhone using TapatalkLast edited by larry_arizona; 12-17-2018 at 07:58 PM.
2021 Supra SA 400
2018 Supra SA 400 (SOLD)
Michigan
12-17-2018, 08:00 PM #16
My boat is at our dock in the summer so trailering is not an option. Over a weekend I usually burn about 20 to 50 gallons and can get away with 10 5 gallon gas fillups . I have 6 cans so that is 2 trips to the gas station. I figure I'm saving at least 10 dollars per can.
Gil Hebert
2014 Mojo
12-18-2018, 12:37 PM #17
Too funny as the best camping and boating is where no one is around and for that to happen civilization as we know it is literally hours away. It was common to have 8-10 gas cans in the boat on a camping trip to be used boating and the remainder going into the motorhome for the trip back. All of the cans were empty on the trip back home. It was interesting when I got gas at Costco and pulled out all the cans from under the tonneau cover knowing I won't be going anywhere for about 20 minutes and at least two resets of the pumps.1998 Mobius
SOLD
12-18-2018, 03:28 PM #182008 Moomba Mobius XLV. Monster Cargo Bimini, WS Rev 410's, Polk Cabins, 3 Infinity Subs, PPI amps, WS420, Exile BT, upgraded ballast pumps, up to 3,500+ pounds of ballast, Blue LED's...
www.TraysonsToybox.com
12-18-2018, 03:31 PM #192008 Moomba Mobius XLV. Monster Cargo Bimini, WS Rev 410's, Polk Cabins, 3 Infinity Subs, PPI amps, WS420, Exile BT, upgraded ballast pumps, up to 3,500+ pounds of ballast, Blue LED's...
12-18-2018, 10:44 PM #20Overkill is underrated
2006 Supra 24SSV Gravity Games- traded but never forgotten
2017 Supra SA 400
