Results 11 to 20 of 24
    Oct 2013
    Ft. Collins, CO
    Yes, the cans would have to be elevated. We put a towel on the sundeck and then set the can up there. It works great. I started with the shaker siphon mentioned above and it works great. It's a game changer - I will never pour fuel cans again. But then... I learned about this: https://www.turbosiphon.com/ and it is amazingly fast. I only wish they had a small diameter nozzle on the end so that it could fit in normal automotive fillers - I need to do my own mod.
    1989 Sanger Skier DX - sold
    Mar 2003
    Springfield Missouri
    Get a fuel pump, put on a power connector and a couple of hoses. I do in situ fueling of my motor home where I may be pumping 40 gallons at a time.
    https://www.amazon.com/CarBole-Perfo...tive+fuel+pump
    SOLD
    Apr 2013
    Knoxville TN
    Quote Originally Posted by johnh577777 View Post
    I ordered the Flow-Fast 21 gallon system with 4 extra gas cans last week from overtons. A total of 63 gallons and it says it pumps 8 gallons per minute. Looks like the way to go but it’s expensive, it was either this or a custom made fuel trailer for me. I’m not messing around with 5 gallon cans when it comes to a 65 gallon gas tank.
    https://www.overtons.com/product/det...ystem&i=331183
    It’s also 25% off right now with the code, still expensive though...
    That is a cool system. And yes, pricey.
    Probably 60# per can. That dolly would be nice on the dock.
    2018 Supra SL400
    May 2018
    Little Rock, AR
    Quote Originally Posted by Broke Pilot View Post
    Just get some regular ol gas cans. But here’s the trick... tractor supply sells non certified nozzles! Just screw then on and it’s like the old days. And way cheaper than motorcycle jugs.
    We use them around the ranch on all the cans.
    https://www.tractorsupply.com/tsc/pr...lacement-spout
    +1 Lots of old school gas can conversion kits available on Ebay as well. I have both motorcycle jugs and old school gas cans and the VP jugs are way better for pouring but less easy to store / transport.
    '14 Mojo 2.5
    May 2018
    Default Portable gas tank recommendations
    Isn’t pulling the boat out and going to the gas station easier? Than lugging 13 5 gallon jugs?
    Or just get a transfer tank for your pick up bed.
    Most start at 36 gallons.
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
    Feb 2015
    Gardendale, AL
    My boat is at our dock in the summer so trailering is not an option. Over a weekend I usually burn about 20 to 50 gallons and can get away with 10 5 gallon gas fillups . I have 6 cans so that is 2 trips to the gas station. I figure I'm saving at least 10 dollars per can.
    Gil Hebert
    2014 Mojo
    Mar 2003
    Too funny as the best camping and boating is where no one is around and for that to happen civilization as we know it is literally hours away. It was common to have 8-10 gas cans in the boat on a camping trip to be used boating and the remainder going into the motorhome for the trip back. All of the cans were empty on the trip back home. It was interesting when I got gas at Costco and pulled out all the cans from under the tonneau cover knowing I won't be going anywhere for about 20 minutes and at least two resets of the pumps.
    SOLD
    May 2013
    If you're spending $13 on the replacement spout, you might as well just get the VP jugs. Just my opinion. I love how the VP jugs fit perfectly under the tonneau cover of the F150.
    www.TraysonsToybox.com
    May 2013
    I have the turbo siphon. it works well. sometimes I'll use it, and sometimes I'll just pour straight from the VP jugs. It's damn quick for the vp jugs to dump 6 gallons through the 1" hose.
    Sep 2015
    Conroe, TX
    Maybe... but how many gas cans do most people have already? If you’re anything like me, 4-5 just in the garage. Buy one nozzle and move it from can to can. Our tractor holds 15 gallons of diesel. That’s what we do.
    Overkill is underrated
    2006 Supra 24SSV Gravity Games- traded but never forgotten
    2017 Supra SA 400
