Results 11 to 16 of 16
    May 2018
    Cool thanks, I will check all hose clamps first.
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
    Jun 2018
    any updates on what OP and Larry_arizona found? Im having the same issue on my '17 Mondo. Oil is clean and hull is dry as well.
    Thanks
    2017 Mondo
    Quote Originally Posted by FFJesse View Post
    Thanks
    Start the boat, let it reach 155+ then check all the hoses. If you have a heater, check the pump near the rear port side engine compartment.
    2006 Moomba Mobius LSV - Sold
    Jun 2018
    Kuna, Idaho
    Had the same issue when we winterized last year, no coolant in the tank at all. Dealer wasn't concerned. We topped it off at the beginning of the season. I will double check tonight.
    2018 Max - Wetsounds - Wake Makers upgrade
    May 2018
    Not thrilled with Indmar hose clamps.
    Otiker clamps really are not adjustable and certainly not reusable.
    2021 Supra SA 400
    Michigan
    There is another thread on this issue. My 2016 CRAZ was also low on coolant. I got an overheat warning and took her to the dealer and all it was that the coolant was low. They checked for leaks and there were none. I think these engines consume coolant, which can’t be good. I haven’t added coolant to my cars in many years, why should a marine engine be any different?
