Results 1 to 10 of 13
    Default Manifold draining
    Manual for 14 indmar 330 engine shows this pic to drain manifolds. Cant find this on mine tho, just have two hoses at front that T off near v drive. Am i missing somethg? Did they change it up and not update?
    2019 Moomba Max
    Aug 2011
    Commerce Lake, MI
    There should be a hose connecting one exhaust manifold to the other. Look again.
    2017 Moomba Craz
    There is a hose, but it T's off into a 3 way valve, with small drain hose near V drive. I dont have whats in the pic from manual. Is this the same thing? Just curious cause its pretty diff from whats in manual.
    2019 Moomba Max
    Jul 2002
    London Ontario Canada
    Some off the pics in the manuals are old. Thats what I had on my 99 outback
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
    Feb 2013
    Knoxville TN
    Quote Originally Posted by Karl View Post
    That pic is a motor that has the quick brass disconnect.
    https://www.bakesonline.com/indmar-h...iABEgIaSfD_BwE
    If you do not have that, the objective is still the same, getting the water out of the exhaust manifolds.
    Disconnecting those hoses and putting them lower in the bilge will cause the existing water to run out.
    Is that what you found?
    I did exactly that, not much water came out tho. Figured it was the same, but curious since diff and not much water drained out. No other hoses on them tho.
    2019 Moomba Max
    Aug 2016
    Freeland, Mi
    What is the reason for draining the exhaust manifolds? If there is antifreeze in them for the winter they should be fine correct?
    2004 Mobius LS
    I don't think everyone fills with antifreeze, a lot of folks simply drain all the water.
    2019 Moomba Max
    Apr 2013
    Knoxville TN
    Quote Originally Posted by twisters6 View Post
    What Karl said.
    Same debate each year on here and on the Supra site:
    1) Drain water only
    2) Drain water and fill with antifreeze
    2018 Supra SL400
    May 2018
    Trying to figure out why you would skip antifreeze if there is any risk of freezing.
    Plus the added benefit of corrosion resistance/protection of antifreeze.
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
