Results 1 to 9 of 9
    Aug 2006
    Lake of Biel, Switzerland
    Default Mobius LSV 07 vs. Outback LSV 07
    Does anyone know, what is the difference between these two models. It looks like that the Mobius LSV 06 is now named Outback LSV 07- but what is new with the Mobius LSV 07? Any suggestions?
    Feb 2006
    Louisville, KY
    Default Not a lot
    Same hull. Same interior.
    The differences are these:
    Mobius series comes with tower, Outback series tower is an option.
    Mobius series comes with ballast, Outback series ballast is an option.
    Mobius series comes with different graphic options then Outback series.
    That's about it. If you want the wakeboarding accessories, Mobius is your answer.
    SC MARKETING
    ________
    Honda CR60
    Oct 2005
    Central FL
    This is true of both the LS and LSV lines - 4 boats all the same hull, design, interior, etc. LS is Direct Drive, LSV is the V-Drive (duh) - the "Outback" and "Mobius" only differ in that the Outback line is not as "wakeboard only" and therfore slightly less expensive, the Mobius comes ready to wakeboard professionally. All 4 boats have been this way for the past few years. The only change was when in '06 they went to a larger hull for these 4, they added a new boat to the entire product line - the '05 LSV was such a great/popular hull/setup that they kept it around and made it an entry level v-drive boat for someone who wants all the ability of the Mobius LSV, just slightly smaller and a good amount less expensive than the new "Mobi."
    Hope this helps expand on the official response. (probably not)
    -J
    Aug 2006
    Thanks, that helps me out.
    Dec 2004
    Cinci-Dayton
    I believe the 07 Mobius LSV is a new bigger boat than my 05 which was the same as an outback LSV. The Mobius LSV is bigger than the Outbak LSV in 07 - check that, I'm not buying one but I rode inthe new MObius LSV and it is a different boat.
    SD2
    Feb 2006
    Louisville, KY
    Mobius LSV 07 and Outback LSV 07 are both larger boats than the '05 LSV. And you are right, that hull is today's Outback V.
    Dec 2004
    Cinci-Dayton
    hijack - I would like to someday upgrade to the stainless steel rub rail. If the outback has changed will a rail for the 05 LSV still be available in a year or two?
    Feb 2006
    Louisville, KY
    Default Hijack
    We keep parts in stock for as many as 10 years after a model year change, so you should be fine between now and 2010 on the conservative side.
    Dec 2004
    Cinci-Dayton
    tx
    sd2
  1. Mobius vs Outback
    By bmoorewiz in forum General Chat
    Last Post: 02-21-2008, 02:16 AM
  2. Outback LS vs. Mobius LS
    By Garn in forum General Chat
    Last Post: 08-27-2007, 06:18 PM
  3. Mobius vs Outback
    By Yellowmobius in forum General Chat
    Last Post: 07-09-2003, 03:54 PM
  4. Outback LSV vs Mobius LSV
    By Laurence in forum General Chat
    Last Post: 01-19-2003, 07:25 PM
  5. Outback LSV vs Mobius LSV
    By in forum General Chat
    Last Post: 01-17-2003, 06:34 PM
