Results 1 to 3 of 3
    Jan 2009
    Calgary, Alberta
    Default Engine not drawing water
    Hi all! I have a 2004 XLV with the Indmar 340. We had a great summer with no issues and the boat ran great. I was going to winterized it today by adding RV antifreeze after draining the block and blowing out the lines. Did the usual pulling off of the raw water inlet hose and attaching another hose into a large bucket of antifreeze. Started the engine and in previous years, it has sucked up the antifreeze pretty quick. This time...nothing. Put the water inlet hose back on, hooked up the garden hose to the snorkel on the belly and fired it up again. Ran great but no water coming out the exhaust. Checked the belt and pulled the impeller - both in good shape.
    Any ideas as to what I’m missing or what might be wrong?
    Kevin
    2004 XLV - 340 HP
    Apr 2013
    Knoxville TN
    Once you drain the water, make sure everything is connected properly and clamps are tight.
    Probably air trapped in the line and not allowing it to prime.
    Put some anti-freeze in the line.
    Someone else was just posting a lout the same issue.
    2018 Supra SL400
    Jul 2002
    London Ontario Canada
    Quote Originally Posted by MJHSupra View Post
    A clamp must be loose, its sucking air
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
