Results 1 to 8 of 8
    Jun 2016
    Alberta
    Default Ballast impeller replacement
    Hi, any recommendations on how often to replace the ballast impeller? They're all filling and draining properly. I've read annually and/or 100 hours, but what if you don't use the ballast often? Should I just wait until there is some kind of symptom? I was quoted an extra $475 for that with my usual winterizing, seems high.
    Oct 2013
    I got 250+ hours never a problem you can take them out and see how they look
    2013 outbackv
    Jun 2016
    Alberta
    Quote Originally Posted by Birdman View Post
    Thanks, I'll let them be for now, they're working perfectly, I'm not sure what $500 would get me.
    Feb 2017
    Colorado
    Quote Originally Posted by drlynes View Post
    New impellers... and lots of labor. Just pull the covers and do it yourself, they will either be dried out/damaged, or in good shape/usable. Heres a video:
    https://www.youtube.com/watch?v=im4Xz7yvzd0
    Jul 2002
    London Ontario Canada
    leave them alone if they are working. I suck p antifreeze from theban fill hose thru the pumps to winterize and mine are 9 years old and still running.
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
    Oct 2010
    Lake Wylie NC Area
    Engine raw water pump impeller maybe, but not ballast pump impellers. These synthetic impellers last a long time, unless one is left on drain cycle and runs dry. Even then, they are resilient.
    IMO, keep a spare and the tools needed, and change on the water as needed, if one fails. Other wise, I doubt they need serviced sooner then 4-5 years, depending on use. In that case, id gauge on number of outing, rather then boat engine hours. Figure 15-20 minutes run time per pump, per trip out.
    Apr 2013
    Knoxville TN
    No standard rule of 100 hrs. If they are sticking or you are getting slow fill times, time to replace. I'm on year three or four.
    I take mine out every year during the winter. Easy access.
    I did aftermarket Johnson pumps in my 07. They came with a black impeller. Year two they started to stick and blow fuses. Replaced with the orange ones. Softer. No more issues.
    Jabsco uses he green replacements.
    $4-500 sounds like a lot of labor. Not sure what they need to take remove to get access. Probably $100 in parts. Dealer might get them cheaper.
    https://www.amazon.com/Jabsco-Impell.../dp/B076GX3WCN
    2018 Supra SL400
    Apr 2013
    Knoxville TN
    ^^^^ This ^^^^
    2018 Supra SL400
