Results 1 to 9 of 9
    Default 2008 LSV tracking fin help needed
    front tracking fin is bent over flush with hull--is this thru bolted or just screwed in from the bottom--would like to know if the gas tank has to be removed -any advice would be appriciated if youve replaced one yourself
    stacy
    May 2003
    south east michigan
    I cant answer your question since Ive never had to change one,but I would like to know how did you bend it over.Those fins are pretty strong!
    jy
    Jan 2018
    Lexington, KY
    I replaced them on my direct drive Supra last year (so there was no fuel tank in the way). They were fastened with flat head machine screws from the bottom and nylon lock nuts inside and glued with 3M 5200 (or some other really gnarly stuff). They have used the exact same casting for decades (my 1986 has the exact same part number fin as my 2018 ), so you should be able to order that part from Skier's choice.
    SC part number: 102820
    2018 Moomba Craz | Autowake 2.0, Zero-Off, G6 Pumps | Captain Blue/Dark Graphite/Silver Flake | Enzos + Lead
    Haven't replaced one but I'm so it's thru bolted like the strut. You'll know as soon as you try removing the bolts they'll probably spin.
    2006 Moomba Mobius LSV - Sold
    Aug 2015
    Spokane, WA
    They are thru-hull bolted. You’ll have to pull the fuel tank, which is actually quite simple. It’s also a good opportunity to scrub the bilge while it’s out.
    Unscrew the two floor panels, pull up. Disconnect the fuel hoses and the tank will lift right out. You probably want to syphon out the fuel first.
    It’s an easy job!
    2008 Moomba Mobius LSV
    thanks for the heads up on being thrubolted--figured it was but hopefull that the gas tank did not need to be pulled
    the owners are not sure how it happened-friends of mine who bought my old boat. they think there kid did it when he was out on it. something about a keg being used as balast.......
    something about a keg being used as ballast.......
    Sounds like a logical plan to me.
    Jun 2017
    Pendleton, Indiana
    For some reason they couldn't figure out why the wave was crap at the end of the day
    2012 Mobius LSV (Sold)
    2020 Mojo
    Well, you can't exactly recycle the beer back into the keg.
