Results 1 to 10 of 18
    Aug 2018
    Default Moomba Max, water fountain behind swim plate! Any suggestions?
    See Video : https://youtu.be/yNpTouS6R1s
    loaded at approx. 5000lbs ballast (100% surf side, 90% offside, 60% bow)
    wake plate = 0
    surfside plate = 70% (happens between 55-85 though)
    speed 11mph
    Any suggestions?
    2018 Moomba Max (5925lbs ballast)
    2013 Tigé RZ2 (sold)
    Aug 2011
    Commerce Lake, MI
    Does it really matter?
    2017 Moomba Craz
    Aug 2017
    Love how much fun your daughter is having!
    2019 Supra SL450
    Quote Originally Posted by Shoebox View Post
    Second that! Awesome. She'll be team SC before you know it!
    Apr 2013
    Knoxville TN
    Reminds me of one of those Yamaha wave runners.
    Nice video.
    2018 Supra SL400
    Apr 2013
    Knoxville TN
    Did you get that happening with the stock ballast or when you loaded it up with more weight?
    You could have the platform mounted closer to the boat.
    Or put something on the bottom of the platform to prevent the water from being forced up.
    I would leave it, but it’s not my boat.
    2018 Supra SL400
    Aug 2018
    Yeah she is 8 and this year started ropeless + starting unassisted like an adult. She loves it!
    I haven't tried with just the stock ballasts, but can't imagine running the Max without it!
    I'd mount it closer, but those sharp wakeplates would be close to sticking out further than the swim platform (a little risky for kids)
    May 2018
    DFW, Texas
    Have the same ballast as you (also agree, 4500-5000 is the max magic number and can’t imagine without). Should be going out tomorrow and will take a look at the platform and see if I have the same thing going on as well as my gap. Do you have FAE?
    2018 Max - Ultrablue flake/Gray - 4400 lbs water (720s midship), 750 lbs lead somewhere
    Jan 2018
    Lexington, KY
    I've got a bit of the fountain going too (Craz with 44-4500 lbs ballast). I assumed it was engine exhaust water doing something weird around the flapper since it's biased to that side (on mine).
    I've seen it a little worse than this picture shows, but doesn't really concern me.
    2018 Moomba Craz | Autowake 2.0, Zero-Off, G6 Pumps | Captain Blue/Dark Graphite/Silver Flake | Enzos + Lead
    Apr 2013
    Knoxville TN
    If the wake plate is slightly adjusted down, I would assume less would be pressure being forced under the platform.
    2018 Supra SL400
