Results 1 to 3 of 3
    Aug 2018
    Nebraska
    Default Now Fuel pump issue .
    So after removing the dash and guages for non-functional guages . The fuel pump stopped working. Check the injectors and nothing was happening . Went back to the fuse and its was smoked black as can be . Changed the fuse and still the same wont turn on . Took the voltmeter and I'm getting nothing to the fuel pump relay , the other 2 relays are getting power .
    Chance that because the fuse was smoked so bad that it actually traveled down to the fuel pump itself ?
    No this was a engine put in , not the factory and whoever did wins the award for the WORSE wiring I have seen . I have wires just hanging on the engine that are not plugged into anything , have ring terminals but not into anything etc .
    I tested all 3 relays and they are all good so it didn't blow the relay itself . It's literally at the plug in the harness .
    Any ideas as to what else to try guys ?
    Thanks in advance
    Aug 2018
    Nebraska
    Problem solved !! After literally weeks trying to figure this guage and then fuel pump issue out .....it all boiled down to 1 wire on the ignition was not hooked up to the proper connection . Changed it to the 12v in switch.....problem solved. Guages and engines fired up perfectly
    Aug 2011
    Commerce Lake, MI
    Cool!
    2017 Moomba Craz
