Results 11 to 20 of 39
Thread: Bag fill/drain hose
09-25-2018, 09:05 PM #11Senior Member
- Oct 2013
- 135
09-25-2018, 09:13 PM #12
09-25-2018, 09:32 PM #13
The Bosworth (sold by wake makers) check valves are a rubber flapper style. They are prone to staying open because the rubber flapper learns some muscle memory. If there is direct positive flow against it, it will seat the flapper. if we are trying to just stop some passive drain pressure, it will flow right past that slightly cracked open rubber flapper.
09-25-2018, 09:42 PM #14
They are not flapper or plunger type. Ive tested ever marine and many non-marine valves over the past 12 years.
09-25-2018, 11:29 PM #15
They won't stop passive drain, regardless of which check valve it is, because the flow direction is from the bag out the vent. However, they don't do much when emptying the bag to keep air from flowing back into it from the vent. I still got a lot of air back into the bag - until I installed the ball valves.
And you still didn't say which valves you use that work so well.2019 Supra SL450
09-26-2018, 08:25 AM #16Senior Member
- Aug 2017
- 1,382
Bag fill/drain hose
Perhaps you’re mounting them backward? I don’t understand your comment. I am not sure why you want zero air back into the bag on draining...
I think he is saying that they will stop passive drain.....or there would be no reason to use them.
I believe Mike has a valve that is working for him. Mike has a crapload of experience more than any one of us yokels in this department, therefore I am inclined to believe what he says. He would have no incentive to make a false claim in this arena, since he installs ballast and sound for a living....
What valve it is? Not sure. Mike can answer that.
As far as the WM valves, I know some folks have good luck. I found them a little inconsistent on their release, so I just removed them to be safe. Certainly not a complete indictment of them, just what I decided to do.
09-26-2018, 08:59 AM #17
If you are mounting them such that they stop passive draining, you are also not allowing them to vent, and may as well just cap the vent port on the bag and not use it. They should be mounted to allow flow overboard, or they are useless. The only reason to use one at all is to stop the air from backfilling the bag and allow a more complete drain.
What valve it is? Not sure. Mike can answer that.Last edited by Shoebox; 09-26-2018 at 09:02 AM.
2019 Supra SL450
09-26-2018, 09:09 AM #18Senior Member
- Aug 2017
- 1,382
Huh.......ok. I personally would primarily use check valves to prevent passive draining of a full bag. Since it directly impacts the surf experience in a negative way.
I don’t think anyone ever used them back in the day before bags got so big?
I get the best drain possible by running the drain pumps while the boat is nose high.
I guess Mike can speak for himself! He knows his doo doo.
09-26-2018, 09:15 AM #19
09-26-2018, 09:28 AM #20Senior Member
- Aug 2017
- 1,382
The check valves are designed to release at a little bit higher pressure point than the water exerts. From what I understand. So they’ll release with air but they will not release with water.
I guess I’m wrong possibly?
