Results 1 to 2 of 2
Thread: When to Winterize?
11-02-2006, 05:12 PM #1
When to Winterize?
So, it's dipping down to 30 degrees tonight and I'm wondering if I need to run home and franticly start pulling hoses and plugs. I had planned on taking the weekend to winterize the right way. Oil change, impeller, wash and wax, etc... but it appears that the seasons' first freeze is running a little earlier than my schedule. What's the verdict on freeze up if it's only going to be 30 tonight and going back up to 55 tomorow? Can it make it through the night with no consequences?
11-02-2006, 08:39 PM #2Senior Member
- Dec 2004
- Cinci-Dayton
- 1,014
30 F you are likely fine if you can throw a light bulb in with the engine even better. Some guy on another site busted everything - it got to -10 C/F - not sure.
If it were me - I'd be frantic even though you will likely be fine.
Rather than panic, hook RV antifreeze to the intake, start the engine and run until it comes out - them do a proper job on the weekend.
don't forget teh heater coil if you have heaters.
SD2
New Boat Winterize
By beckman2713 in forum Service & RepairReplies: 47Last Post: 01-27-2008, 11:27 PM -
RUSH TO WINTERIZE?
By 04OUTBACK in forum General ChatReplies: 2Last Post: 01-05-2008, 01:43 AM -
How do you winterize an inboard on your own?
By gsi09907 in forum General ChatReplies: 4Last Post: 08-15-2007, 09:33 PM -
Do you winterize your boat?
By TheBeeZ in forum General ChatReplies: 5Last Post: 10-13-2005, 09:39 PM -
winterize mufflers
By Yellowmobius in forum General ChatReplies: 0Last Post: 10-24-2003, 09:56 AM
