Results 1 to 10 of 10
    Jul 2013
    Massachusetts
    Default Trailer dragging/hot wheel
    So I've noticed my '07 Boatmate seems to be dragging lately. I noticed today one of the wheels, lugs, and hub was hot to the touch. I've had the brake system checked after I had to replace the axle in '13.
    Anyone have experiences like this or know what it could be?
    Jr.
    '08 Outback V
    May 2016
    West Milwaukee, WI
    Check your bearings. Either you'll need to replace oil (oil bath) or relube (grease fittings). If it's getting hot, they'll fail and you'll lose the wheel on the highway.
    Sent from my OnePlus 5 using Tapatalk
    2004 Mobius LS - hooked on footin'
    Former tow: 1986 Chaparral 178 XL, 90hp Merc
    First tow: 197x Glasspar Citation, 135hp Merc
    Aug 2011
    Commerce Lake, MI
    Is it super hot at the center of the axle/hub cap? If so could be a failing wheel bearing and must be replaced ASAP. Don’t dick around with this: get it fixed immediately.
    2017 Moomba Craz
    Apr 2013
    Knoxville TN
    Today there was a few pics on Facebook of this - wheels completely off.
    2018 Supra SL400
    Jan 2017
    Thompson lake maine
    If it’s dragging it’s most likely a stuck caliber
    Apr 2012
    Wake Forest, NC
    Quote Originally Posted by Catman View Post
    Agreed. This happened twice on my 2008 trailer over 10 years of ownership. If the wheel is covered in brake dust that definitely the issue.
    2018 Murder Max
    2008 Outback V-Bought new; sold in 2018
    Put the trailer on jack stands and grab the wheel at the 3 o clock and 9 o clock positions and try to wiggle side by side. There should be almost no noticeable play. Repeat this at the 12 o clock and 6 o clock positions. If there is no play then your wheel bearings should be good. Next try to turn the wheel. It doesnt spin freely then inspect the brake caliper. Good brakes 5 years ago does not mean good brakes today.
    Jul 2013
    Massachusetts
    Seems to be brake than hub. Wanted to troubleshoot the brakes today but had some electrical issues last night that took priority.
    Just in case, anyone have experience in changing out the inners of the surge system?
    Jr.
    '08 Outback V
    I replaced my surge unit a few years back when I did all new bearings and brakes. They’re not too bad. Bleeding is about the only tricky part. Just takes patience.
    My brakes on the Mojo only lasted 3 years, had to replace them in 16 before the trip to GA, since we have arrived in GA i bet I have only pulled that trailer 10 miles LOL.
    [COLOR="#696969"]
