Results 11 to 17 of 17
Thread: 2001 Mobius MDC location ??
08-22-2018, 09:46 PM #11
Another solution to at least your speedo problem is something like this...
I have doubts though that there's an MDC hidden anywhere in there - yours or mine.So when is this "old enough to know better" supposed to kick in?
08-22-2018, 10:34 PM #12Member
- Aug 2018
- Nebraska
- 88
08-22-2018, 10:37 PM #13Member
- Aug 2018
- Nebraska
- 88
The grounds on the circut board , under the guages main harness etc ....where do they go ? Your pic looks like they go UP from the circut board
08-27-2018, 01:29 PM #14
That year SHOULD have a MDC. Mine was a DD but should be similar - the key is to follow the pitot tubes, they plug directly into the MDC brain. They're hateful and prone to damage. Also, no longer available from Medallion...
From a post I just replied to:
Very familiar with that darn MDC...
It's located in this right rear corner behind the flexible carpet strip (in the rear locker). At least 2 screws to remove at the floor level, about 1' in from each end. Entire flex strip comes out. Follow small diameter pitot tubes (speedometer hoses) back to brain. This is how they fail BTW - diaphragms fail internally then water gets pumped into the control boards from the speedometer pickups.
2008 OBV
325 EFI with closed cooling
Gravity III with 750's in the rear, 400 stock floor, 750 IBS
Servo valve ballast upgrade
Wetsounds Rev10
JL Amps, WS420BT
2000 Outback LS <-- Sold!!!
310 Carb Direct Drive
800# Rear Locker
750# IBS (should have kept this for the OBV)
Dual Batteries with 2 Bank Charger System
Kenwood Head with Remotes
Too many hours restoring exterior from prior negligence to count!
09-01-2018, 05:46 PM #15Member
- Aug 2018
- Nebraska
- 88
There is no MDC on this boat I assure you Haha!! I have literally ripped the interior out of the boat including the ski locker ....nothing. The speedo "tubes" which are 2 wires with 3 wires inside each go to speed wheels one on each side of the rear of the boat . Guages still arent working. Hooked everything up the way it should as I downloaded a wiring guide from Indmar and still nothing . The ballston, bower etc every single toggle works off the board but no guages . Ignition works properly as well it's literally just the guages . Put the guages on a bench and tested all , all tested good . There is something missing that I'm not picking up on . On the circut board there is multipul grounds which I believe come from the breakers in the panel above . The actual guages are gro unk ne through the wiring harness back to the engine where they connect into relays then into a small fuse panel . Have tested all the relays and they are all good however the fuel pump fuse was popped and melted . I'm now wondering if it's a ECU issue .....I wouldn't thnk this however I'm running out of options at this point
09-01-2018, 06:57 PM #16Senior Member
- May 2016
- West Milwaukee, WI
- 283
I'm almost certain that mdcs are only used on boats that use pitot pickups for speed reading to convert water pressure to an electrical signal.
Paddlewheels are an electro mechanical device, so no mdc is needed.
Pretty sure.
Sent from my OnePlus 5 using Tapatalk2004 Mobius LS - hooked on footin'
Former tow: 1986 Chaparral 178 XL, 90hp Merc
First tow: 197x Glasspar Citation, 135hp Merc
09-01-2018, 07:10 PM #17Member
- Aug 2018
- Nebraska
- 88
