Thread: Surf tabs
08-11-2018, 11:39 AM #1
Surf tabs
When surf switch is in the neutral position, the starboard plate hangs down approx. 1/2 inch lower. Is this normal?
Sent from my SM-G955U using Tapatalk2017 Moomba Mondo
1120 rear lockers
500 center hard tank
750 ibs
2-650s in the floor
Acme 2079 prop
08-11-2018, 01:39 PM #2
08-11-2018, 01:57 PM #3
Ok I think they are. I will have my wife switch them while I watch to see if they are moving correctly.
1120 rear lockers
750 ibs
2-650s in the floor
Acme 2079 prop
08-11-2018, 05:19 PM #4Senior Member
- Aug 2015
- Spokane, WA
- 262
Check to see if the transom actuator bracket isn’t bent. I had someone decide to use my port side trim tab as a foot step climbing out of the water and bent/snapped the actuator bracket right off.
Sent from my iPhone using Tapatalk Pro2008 Moomba Mobius LSV
