Results 1 to 6 of 6
Thread: FS: Wetsounds SYN-DX4 Amp
08-02-2018, 04:29 PM #1
Like New
Used less than a year
Powered one pair of Rev10s
Added an additional pair of Rev10s
Upgrades to SD2
$400 OBO
Sent from my iPhone using TapatalkGarrett
2017 Moomba Mojo
Flow 2.0 Surf MAX Package
Black/Brittany Blue Metal Flake
w/ Striker Graphics
08-03-2018, 11:21 PM #2Senior Member
- Oct 2016
- Tims Ford Lake TN
- 453
Would this be a good option to power 4 Exile 9” tower cans? It would be to replace an Exile 30.2
2016 Mojo Surf
Raptor 400
1100 rear bags / 500 IBS / 600 LeadWake
Exile amps/tower - Kicker in-boat
FAE
08-06-2018, 08:04 AM #3
Why are you replacing the 30.2? Its more then enough power to run 4 XM9s
I have been running 4 XM9s since 2013 on a 30.2 and never an issue, even my gains are still turned down and trust me when I say my tower is loud. I have more amp left then the speakers can handle.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
08-06-2018, 09:30 AM #4Senior Member
- Oct 2016
- Tims Ford Lake TN
- 453
[QUOTE=mmandley;330322]Why are you replacing the 30.2? Its more then enough power to run 4 XM9s
Because this is the 2nd 30.2 to crap out in as many years. Credit to Exile, last year they sent a replacement, but now the replacement has failed the exact same way as the first. It is frustrating, no fuses blown, not driving it to hard (never into protect mode)....clean inputs and just no output. As you allude to, it powered the cans fine. So, don't want to hi-jack the OP's for sale thread. I may post my own so folks can chime in with thoughts on what this Gremlin may be.2016 Mojo Surf
Raptor 400
FAE
08-06-2018, 04:37 PM #5
08-06-2018, 04:47 PM #6
I’m honestly not sure. I’m not too familiar with the XM9s.
Specs on the amp are as follows...
Specifications:
Stereo @ 4 Ohms: 125 x 4 watts RMS >1.0% THD
Stereo @ 2 Ohms: 200 x 4 watts RMS >1.0% THD
Mono @ 4 Ohms: 400 x 2 watts RMS >1.0% THD
Frequency Response: 20 Hz - 20 KHz
Crossover Range Low Pass: 50 Hz - 250 KHz 12dB/Octave
Crossover Range High Pass: 50 Hz - 250 KHz 12dB/Octave
Input Sensitivity: 0.2 V - 6.0 V
Hope this helps.
2017 Moomba Mojo
w/ Striker Graphics
