Results 1 to 10 of 17
Thread: 2010 Moomba LSV
07-31-2018, 09:21 AM #1
2010 Moomba LSV
Still lots of summer left. $38,900
Selling my gently used 2010 Moomba LSV with 242 hours. Throws a great surf wave.
Upgraded Ballasts (1100lbs in rear), 600lb in the locker and 600 in the bow
Heater
Gravity III with reversible pumps
Single axle trailer
Upgraded Clarion stereo (3 Kicker Amps plus 12" sub) with Bluetooth Remote
Krypt Tower speakers
Krypt Fold-in Surf / Wakeboard Rack
Endless Surf Rack (classic)
Dual battery
Great shape. Extremely well maintained.
I’ll also give you two fat sacs, external pump, two surf ropes and wake shaper. (Total Value $700)
If you are in Michigan, I’m also selling my hoist 4600 lb with Barn Style Canopy.
Will need a larger Hoist for a Moomba Max (not ordered yet but looking for a Blue Metal Flake on white Max)
Sent from my iPhone using TapatalkLast edited by MichiganMoomba; 07-31-2018 at 09:22 AM. Reason: Buying new Moomba
2010 MOBIUS LSV
07-31-2018, 09:55 AM #2
This is a great boat guys. Chris and I dialed in the surf wave on this thing (using a wave shaper I made him) and it is money!!
If you’re looking to get into a good sized, economically priced V-drive that can hold its own with many of the newer boats in terms of wave size and quality, then look no further.
Here some more pics I have from numerous sessions
2017 Moomba Craz
07-31-2018, 11:37 AM #3Senior Member
- Aug 2015
- Spokane, WA
- 262
Great looking surf wave! How are you distributing your weight, what speed are you running and wakeplate setting for goofy. I’ve been struggling a little this year to clean up my goofy side wave on my 08 LSV. I have a similar ballast set up as you. 1100 ea rear, 650locker, 500 bow and 500#’s of lead I’ve been playing with.
Thanks!
Good luck with sale!
Sent from my iPhone using Tapatalk Pro2008 Moomba Mobius LSV
07-31-2018, 12:03 PM #4
That’s surprising as the goofy wave is the best of both sides. We use a wake shaper as far back as it will go under the LSV decals and run 11mph with wakeplate all the way up. All bags full and a 400 across the seat and another 400 on the surf side seat that we move to whatever side we surf on.
Sent from my iPhone using Tapatalk2017 Moomba Craz
07-31-2018, 12:09 PM #5Senior Member
- Aug 2015
- Spokane, WA
- 262
I used the mission delta last year and was happy with the improvement. Last fall I had the auto flow 2.0 tabs from wakeland installed and have been tremendously happy with the results. From what you said, sounds like I need to move my lead further back. I currently have 100#’s bow, 200#’s port and starboard midship. I’ll try moving all the lead to the back and see how that does. Are you 100% full starboard and 80% port?
Thanks I appreciate the help!
07-31-2018, 12:10 PM #6
The reason your wave is now better on the Goofy is the surf wedge.
I always have to make both waves great as my wife surfs goofy. We had an 08 LSV for a while and this was before the wedge, flow, auto systems.
On the Mojo I had the same problem, I even made a wake plate attachment to clean up the goofy wave and it did a great job. But it did weaken the regular wave a little.
Now I have the Wake Makers auto system and my Goofy wave is killer, but the Regular wave is now a lot weaker. Its always a give and take, but I am actually hopping
the new wedge I got plus the auto system will fix that issue as well.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
07-31-2018, 12:11 PM #7
I think we do take a little bit out of the non Surfside. But it is key to have as much weight to the back and to the surf side as possible
07-31-2018, 12:13 PM #8
07-31-2018, 12:17 PM #9Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
07-31-2018, 12:19 PM #10Senior Member
- Aug 2015
- Spokane, WA
- 262
I have been wanting to try the mission delta wake shaper with the surf tabs and see how that works!
