    May 2006
    Cookeville, TN
    Default Trans and V-drive fluid
    Do any of you ever change the Transmission and/or V-drive fluid in your moomba?
    This weekend while winterizing, I accidently pulled the fluid drain plug on the v-drive thinking that it was the water drain. A few ounces of fluid drained out. How important is it to keep that fluid level exact? I checked the fluid level on the dipstick and it still read full, but that was not at running temp.
    Mar 2005
    t-town
    tn, in regards to checking the correct level of your vdrive and transmission fluid it is always best to do so when the oil is warm, (of course it is really low cold, put some in). i should also be done on the water and not the trailer.
    in regards to your other post, you really need to discuss the engine paint chips and rust with your dealer. i put over 125 hrs on my boat this past summer and the motor, vdrive and tranny still look brand new.
    db
    Feb 2006
    Birmingham
    I change the V-drive fluid and the trans fluid every year. It is so easy and inexpensive to change that I figure it is worth it. I would rather be safe than sorry.
    15 Mondo Surf Edition
    02 LSV - Traded In
    Feb 2007
    I too change the V-drive tranny fluid every year, or 100 hours. Each time I go to the lake I check the fluid after the engine has had a chance to warm up.
  1. atf fluid for v drive
    By rickmcd59 in forum General Chat
    Last Post: 08-31-2006, 12:16 AM
  2. ATF FLUID IN V-DRIVE/ Brian Rammond
    By Aquaholic in forum Service & Repair
    Last Post: 09-28-2005, 12:23 AM
  3. TRANS
    By BUSHSTER1 in forum Boat Owners
    Last Post: 09-15-2003, 10:51 PM
  4. trans fluid change
    By BUSHSTER1 in forum Service & Repair
    Last Post: 05-04-2003, 10:08 PM
  5. Changing Trans Fluid
    By ChipB in forum Sales & Information
    Last Post: 06-26-2002, 10:00 AM
